  • SN95 4.6L Mustang Tech
Can CC Plates change ride height?
  • Thread starter Thread starter fiveoho
  • Start date Start date Feb 20, 2010
fiveoho
1,958
TN
Feb 20, 2010
  • Feb 20, 2010
can aftermarket caster/camber plates cause a car to sit too high in the front (after being lowered)?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Feb 20, 2010
  • Feb 20, 2010
offhand i dont think so... unless someone majorly screwed up with the spacers, but even then i dont think so.
rowapr
15
the burg, maryland
Feb 20, 2010
  • Feb 20, 2010
you "can" if it is a coil over setup. but again you would have to forget some major parts and have the spring resting on the tower.
fiveoho
1,958
TN
Feb 22, 2010
  • Feb 22, 2010
my car just does not have the stance it should. sits too high in the front. upr cc plates, sportlines, es isolators, gabriel replacement shocks/struts. with those springs, the car should be fairly slammed. it isnt tho
pics : http://www.stangnet.com/mustang-forums/806910-cut-sportlines-swap-h-r-ss-springs.html
the guy that done the work used the spacers for the plates, below and above the plate bearing. car rides very smooth. no bottoming out and rides near stock like. i dont know if i should blame the springs or not. just ordered a set of h&r super sports but have not installed them yet.
02SonicBlueGT
540
Ankeny, IA
Jun 24, 2010
  • Jun 24, 2010
I'm actually having the same problem with my car. I just had maximum motorsports cc plates installed and I have eibach sportline springs and tokico 5 way adjustable shocks. The drivers side looks ok but the passenger side is quite a bit higher. The driver side is about 3 fingers from tire to the fender lip and the other side is a little over 4 fingers. any idea what's causing this?
twogts4us
4,188
12
79
Dunedin, FL
Jun 24, 2010
  • Jun 24, 2010
MM CC plates are a bit tricky to install - are you sure they were installed correctly? Do you have a pic of them? Know that the springs will settle... Also, are the springs in the pockets correctly? If they are clocked wrong that will affect the ride height.
02SonicBlueGT
540
Ankeny, IA
Jun 24, 2010
  • Jun 24, 2010
I can send pics later. The weird thing is, I've had these springs on the car for several years and I never noticed the ride height difference until after the plates were installed. I'll get pics of the plates and the ride height tonight. I plan on washing the car so I'll be sure to take some pics.
N8Dogg98
3,872
238
184
MN
Jun 24, 2010
  • Jun 24, 2010
Your car's ride height is determined by the springs. Unless the strut is binding, there is absolutely no reason a CC plate would change the ride height. Double check to be sure the springs are installed correctly and are sitting in teh spring perch in the appropriate position.
H
HOOCBB
90
  • Jun 26, 2010
I didn't find the installation of my MM CC plates tricky at all. Maybe locating the 4th hole to drill could be, but the rest was pretty straight forward.
Suspension CC Plates bushings and sleeves?
  • Scott_S
  • Apr 16, 2026
Fox 5.0 Mustang Tech Apr 16, 2026
Mustang5L5
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
W
Codes P2004 & P2005 after removing the Actuators. I locked them open with MMR Plates. How can I fix this? 2018 Gen 3 out of a Mustang GT into a 67.
  • wdsloan
  • Sep 18, 2025
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Sep 18, 2025
wdsloan
W
