If you have all the right tools? How hard is it to replace the front struts and springs and rear shocks and springs on a 2001 GT? Should I be able to do this myself?
I've never done that before, and if it's simply removing the old parts and replacing then I think I can handle that. I just don't like to mess with anything near the brakes.
I did some searching looking for a write up but I didn't see anything that stuck out. So I need some direction.
My plan is to go with the bullitt kit from ford racing because it's around $400.00 and does everything I need it to do. I don't autocross and the car has never seen a drag strip. It just needs to be freshened up. Will Castor/Camber plates do anything for me besides dressing up the engine bay? And will it make it easier to do an alignment?
Also when and if I finish the install I will take it for alignment
