Can I exchange a 2.25 rack to a 2.50 one?
just dont say anything when you return yours for the core charge.... yeah there the same, there is even a 3 turn lock to lock that you can get too for even cheaper i believe.... good luck, i just changed mine about a month ago...
Right. The 2.25 has a few 5 cent plastic clips in it to keep the wheels from turning as far. You can probably pull them out from your stock one and put them in the new one if you want. The only problem is that when you turn the wheel all the way, it might rub on the fender liner and such.
