ADRENLN said:or is that just for the aluminum 4.6 cobra and explorer blocks? if so is is bad to bore these blocks a little? is there not enough room?
also how would this effect a car that is going to get a blower?
TweekedGT said:I got mine bored .030 over and that is as far as you can go. The cylinder walls start to get a littl thin after that. You put a 3.75 crank in there and it makes a 302.
blackfang said:You can sleeve the iron block for a big bore kit, but the darton sleeves are expensive
svttech76 said:Sure it's cheaper to stroke our motors, but what they really need is more bore. Our bore /stroke ratio stock is worse than a 347 stroker 5.0![]()
the reason a larger bore is better is because it unshrouds the valves and you could also go with larger valves..
If I had the money I would get a teksid block and send it out to be bored/sleeved then I would assemble the engine myself, but I don't have money so stock I stay for now![]()
01Steeda said:every word true.
My 5.4L fox project is going really slow, but I planned it that way...
I am getting a iron block darton sleeved, mainly because the cost of an alloy aluminum (sp? lol) block is rediculous. Bore is 100x better for our engines than stroke. If you have the money for the teksid... get it and go for it. youll make big power.
Exactly!! If I recall, Nazman gained 50 rwhp with just a big bore kit.svttech76 said:Sure it's cheaper to stroke our motors, but what they really need is more bore. Our bore /stroke ratio stock is worse than a 347 stroker 5.0![]()
