Can i get some pics/suggestions?
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Ok so i'm installing my nitrous kit this weekend:banana:, and i know some of you all have the same kit(NX plate). Well guys i was wondering if anyone has pics of thier install and/or suggestions on where to mount the solenoids/wot switch/relay. Just want to know the best place for all of them or just some ideas:shrug:. Thanks in advance :SNSign::flag:
I mounted the WOT trigger on the bolt on top of the plenum that is closest to the drivers side fenderwell. I will take a picture in the morning when it's light outside. I removed my center console panel to install the arming switch and purge button. I heated up a soldering iron and poked it through the plastic, then dremel'd the hole out to match the size of the button/switches. Keeps it close enough to arm/purge when I want to - but not close enough for me to abuse it constantly in daily driving situation ie: mounting on the shifter or inside of a cupholder. If using a remote bottle opener or open/close solenoid on the line then just run those wires under the backseat and into the plastic gutter thing that sits at the bottom of the door sill. Then you can route it right up into the console from there with a few zip ties to keep it clear of the pedals. I mounted my 2 solenoids on the drivers side of the plenum on the mounting plate that came with my kit. Pick up some black electrical tape to tape all of the wires together for a nice tight clean look and then put the wires inside of some 1 inch conduit.
Ok so new problem. My fuel solenoid is leaking:shrug: Has anyone had any experience w/ this kit? Any advice is welcome. It's almost like the fittings aren't tight enough on the solenoid itself, but i cannot get them any tighter.
