jaidedeye said:
thanks for the diagram. so what should i do with the nuetral saftey switch wire to bypass the switch?
so you just want to bridge the connection so you can start the car? if you bypass the switch, the car can start in gear, which is a safety concern. there have been threads in here where competant stangers bypassed the switch and lurched the car through something - one guy actually had the car take off on him. (i know you know this, but i have to say it, as it is a safety concern. i would not do it if ANYONE else drives the car).
to hook it up the way it was designed, plug it into the switch on the clutch arm.
to bypass it, one needs to bridge the terminals. one could solder, etc. the wires.
easier: a blade type fuse happens to fit real nice in the two slots on the switch. tape the fuse in, etc so it does not fall out from vibes, etc.
like i said, i dont like to recommend bypassing the switch for reasons i mentioned, but what i said should allow you to do so, if you feel so inclined.
good luck.
