Well its summer and I want to make the most of the extra free time i have so i want to spend some time learning how to do some shadetree mechanic style stuff. I kicked it off by installing my suspension. Now i'm thinking about learning how to port. I used to be heavily into car audio and i bought a Craftsman All-In-One cutting tool as it can be used as a router + lots of other stuff. It's pretty stout, easily cuts through fairly thick wood (goes through 3/4" mdf very easily with the larger bits). I also have the flexible shaft attachment so that i can hold it like a pin and move it around easier for detailing stuff. So anyways, i'm wondering, could i learn how to port with this tool? It has 2 settings, 20,000rpm and 30,000 rpm. Now, i dont plan on learning with my 5.0!! I'm thinking about learning other stuff at the same time, so i thought maybe i'd pull a weed wacker or atv motor apart (i have a few sitting around) and learning on those.
So, can i use this tool? Or will i HAVE to buy a die grinder even just to learn on small stuff like an ATV motor? I'd like to learn how to do porting/polishing and maybe learn about boring etc (probably would have to take it to a speacialty shop for that though right? at least i could figure out how it works or something...).
Thanks for any advice.
-GM
p.s. If i learn it well enough i might try on my intake or something, but until then i'm not touching it. When i do i assume i'll need better tools....
-GM
