  • 1994 - 1995 Specific Tech
Can I remove/install studs without removing axle ?
  • Thread starter Thread starter Stangfreak95
  • Start date Start date Apr 28, 2004
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Apr 28, 2004
  • Apr 28, 2004
I just got some extended studs for my Prostars. Is there a way I can remove the stock studs and put my longer ones without removing the axle ?
I have ABS also ..
Thanks
GTPhreak
5,505
Rowlett, TEXAS
Apr 28, 2004
  • Apr 28, 2004
doubt it...they need to be pressed out/in
Stangfreak95
add a 4
3,571
Apr 28, 2004
  • Apr 28, 2004
I know you can manage to not press them in but using a lugnut and socket or whatever. But I'm more worried about them fitting in the hole with the ABS ring in the way, just behind.
Anybody else knows about this ?
5.0 from 95
738
Emory, TX
Apr 28, 2004
  • Apr 28, 2004
I can get them out of the way with my lug wrench, but I don't know about the getting them in.
Paul
94speedracer
585
JAX FL
Apr 29, 2004
  • Apr 29, 2004
subscribing
4Jenna
4,326
AZ
Jun 22, 2004
  • Jun 22, 2004
I've replaced one that I fudged up...cross threaded
It was a pain though
94speedracer
585
JAX FL
Jun 22, 2004
  • Jun 22, 2004
I just put long studs on mine without removing the axles. You dont have to remove the axle.
BTW the knurl size for my stock axles on my cobra was .615 !!!! this might help as everyone i delt with didnt know... Also use a dremel tool to hone out the holes a little, this will help pull the studs in a HELL of alot easier..
Stangfreak95
add a 4
3,571
Jun 22, 2004
  • Jun 22, 2004
Been a few weeks since I posted that.
Studs are not in yet. How could you get them in/out in the back with the ABS there ?? Seems like it will never work
For the back, I bought the ARP studs, and for the front I got the Moroso which are suppose to have the "special" size for our cars.
94speedracer
585
JAX FL
Jun 22, 2004
  • Jun 22, 2004
I got morosos for the back. they tried to tell me the special size for our cars was .580 which was way to loose. Some brands shave one side of the knurl end to clear the ABS ring. Mine were not so i just aimed them into the holes and smacked em with a hammer to get them past the ABS ring. It just chipped the outer edge of the ring a little. No big deal the sensor is on the opposite side...
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
A
79 mustang pace car spoiler.
  • Anglosaxon83
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2026
Anglosaxon83
A
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Tuesday at 2:05 PM
Kleinjj27
K
