Greetings,
Long story short, I added a blower to my modified 5.0. The bottom end (block, crank, rods, pistons) are stock.... My combo made 488.5 RWHP.
I know this is too much for the stock bottom end if I want it to live long and I was thinking that the rod bolts were probably the weakest link.
My questions are:
1. Is it possible to change the rod bolts while the engine is in the car - assuming I've lifted it high enough to remove the pan? Are the bolts pressed into the rods or can they be removed?
2. Would replacing the rod bolts w/ ARP bolts be the best way to reinforce my bottom end - short of getting a sportsman or dart block w/ upgraded rotating assembly?
Thansk!
My questions are:
Thansk!
