Can I use 2 spacers?
  • Thread starter Thread starter 87foxstang
  • Start date Start date Jul 16, 2010
87foxstang
Cromwell, CT
Jul 16, 2010
  • Jul 16, 2010
Hey, I just did a head swap to TW's. I have 1.6 rr and my stock valve covers dont fit, so i picked up some tall ford motorsport covers up from my buddy.
I need like an inch and a half spacer. The biggest I can find is a 1". Is it safe to stack a 1" and a 1/2"?
ttopstang
306
Birmingham, AL
Jul 16, 2010
  • Jul 16, 2010
I have that set up and I run a 1 inch spacer.
What intake manifold do you have? Do you still have the EGR hooked up?
87foxstang
Cromwell, CT
Jul 16, 2010
  • Jul 16, 2010
I have the cobra intake with the egr still on there. Im hitting the drivers side cover but the worst part seems to be the throttle cable bracket hitting the passenger side cover.
ttopstang
306
Birmingham, AL
Jul 16, 2010
  • Jul 16, 2010
I took the egr off mine, so it moved the throttle cable closer to the intake.
Im running a proffessional products upper/lower crap intake.
87foxstang
Cromwell, CT
Jul 16, 2010
  • Jul 16, 2010
hmm ok, not sure what im going to have to do here. I need 1 1/2" clearance. Hopefully I can stack the spacers
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jul 16, 2010
  • Jul 16, 2010
Are you talking about phenolic manifold spacers? Take two and "glue" them together with black RTV silicone. Let it dry on the workbench, and make sure to clean away any drip, especially inside the ports. Assemble on intake with a gasket on each end. Should work fine.
Keep in mind that effectively elongates the intake ports which will lower your intake's rpm range somewhat. I have no idea how much, but just know that it's there.
Also, mind the hood clearance.
87foxstang
Cromwell, CT
Jul 16, 2010
  • Jul 16, 2010
Hey thanks for the input. Ive been messing around with it. I mocked up a 1" spacer out of wood and put the intake on it I was still hitting the throttle cable by a long shot so i modified it a little and got it to clear. Ran out and bought the 1" spacer and it all clears perfectly
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
Can ya Hemi now?
  • RaggedGT
  • Jul 2, 2026
  • Other Auto Tech
Other Auto Tech Jul 2, 2026
RaggedGT
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
