can it be rebuilt ?
  • Thread starter Thread starter 66moneypit
  • Start date Start date Jun 1, 2006
66moneypit
536
Northern Va
Jun 1, 2006
  • Jun 1, 2006
I have never rebuilt a carb but my dad just gave me an Autolite 4100 1.08. The linkage works fine but the choke seems frozen. Is it rebuildable ? I don't see alot of varnish or anything else inside. Just wondering if I should bother.
5.0ina66
664
Ohio
Jun 2, 2006
  • Jun 2, 2006
No, no carb can ever be rebuilt.
The choke assembly is held on by 2 screws IIRC. If memory serves, a good cleaning and scrubbing of the spring does wonders, as the choke mechanism likes to get gummed up with crap.
Be VERY CAREFUL taking it apart. Autolite carbs are mostly cast aluminum. The last 2100 we tried to rebuild was so rusted up, corroded and had so many of the internals fused in place, I gave up. Aluminum has a nasty tendency to fuse to other metals. If the jets dont come out, soak them in PB Blaster, no WD40 crap will do..
HTH
--Kyle
66moneypit
536
Northern Va
Jun 2, 2006
  • Jun 2, 2006
That does help....maybe I will tackle that this weekend. I have never rebuilt one. I know you said the aluminum fused can make one useless to rebuild...is there anything else I should look at before that would make this carb totally unuseable ? I just don't want to waste the time if the carb is not salvagable.
65mistress
405
Generica USA
Jun 2, 2006
  • Jun 2, 2006
If you learn something new from it, then it's not really wasted time.
66moneypit
536
Northern Va
Jun 2, 2006
  • Jun 2, 2006
That is true....might see if I can find an online video to walk me through it. I have also considered letting Pony carbs redo it but that's not as much fun now is it. The only reason I'd use them is they can test it much better than I can.
A67StangMaster
401
San Jose CA
Jun 2, 2006
  • Jun 2, 2006
pony carbs is a really good place to get your carb redone i buy old holley carbs send them to pony and have a cheap selection of carbs ranging from 250cfm too 1000cfm that i could use... the cheapest way to buy carbs lol.
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
