Can someone help me Please
Shibbydude529
40
ok i have a 1993 gt 5 speed and i was in an accident with it a couple weeks ago nothin serious though just a trip into the trees on a wet road but now the car is starting to run very bad it hops really bad in second feels like its goin to bounce you right outta the car also it has a very rough idle and eventually shuts off i have cleaned out the fuel injectors replaced the spark plugs and wires replaced the fuel filter and the fuel pump is about to be replaced the fuel pressure is between 30-40 and i have no clue what else it could be i have also just replaced the idle air control sensor any help is greatly appreciated
There's not enough information here to even begin guessing. Try describing whens, wheres, whys, hows, and circumstances for when it's acting silly. It sounds as if you're changing engine tune-up parts to try and fix a physically broken piece of the drive train.
Sounds like a broken peice of the drivetrain like Daggar said.
I would check your control arms and shocks and quad shocks(if you still run them). Also check your tranny mount.
well i didnt think it would be a tranny problem cuz it doesnt do it all the time only randomly usually in second gear while goin up a hill it just feels like the engine isnt running like it should it doesnt have the power it used to have do u think it could be a problem with the driveshaft and maybe the u joint sorry if this doesnt help
