Can someone tell me what my combo will run and hp its making
cathartic
220
Ca
I have a 92 GT and I want to know the hp #'s and what you think it will turn in 1/4...
347 .30 over 9.7 to 1 compression
AFR 205 heads
AFM B-41 blower cam
1.6 roller rockers
75mm accufab tb
Holley Systemax intake lower is HEAVILY ported
1 3/4 Long tubes to 3 inch exhaust no cats
alum driveshaft
msd ignition/wires/cap/rotor
UPR chromoly K member with coil overs
Flaming River manual rack
NO AC/HEATER CORE/FRONT CRASH BUMPER SUPPORT/SMOG PUMP/POWER STEERING
Vortech S-Trim 10 rib 2.75 pulley W/AFTERCOOLER and AFM powerpipe and HKS blowoff valve
373 gears
Auburn Pro locker
skinnies in front 10inch slicks in back
line loc
battery in trunk
6 point cage
SSM lift bars
50lb injectors
80mm Pro M mass air
Not sure the specs on that cam, but if its decent, i'd hope for at least 550rwhp on a set up like that. Thats a 9 sec car if it hooks. Should trap at least 130 once tuned. Stock block?
yes its stock block, im praying it holds, my buddy makes close to 600RWHP in his 331 w/stock block for the last year but his was a new block from Probe, but still stock. i have heard some people hit over 650RWHP but I know they are on borrowed time.
It does have a Probe stud girdle though so that helps. If it breaks im going to a 400+ ci so when it does crack it will be just the kick i needed to get more cubic inches and drop in a YS trim :)
