Can you run 12.5:1 compression on pump gas?
agent007kimball said:
Actually it looks like its more like 12.1 - 12.3 compression....will that make it any more feasible?
That's still pretty high for your application. There are cars that go to 13:1 stock (eg the Prius) but the computer can also compensate for detonation and retard timing. IMHO if it is a weekend only/ drag car go for it. If it is more of a daily driver I'd say go with around 10.5:1. I went with 11.5:1 on my weekend car and always have to mix fuel.
Mike
5.0guy said:
do they sell 104 octane at pumps near u?(prolly wouldn't mix it, just run that straight. I know they have 104 unleaded) that should suffice. maybe 110.
Is it realy worth the 4 to 6 bucksa gallon for a point and half compression? Somehting to think about.. How often will you be driving it..?
I have been wondering a similiar question. It sounds like 11:1 is the max for pump gas. I am looking at buying a CHP dynotec longlock 347 with 11:1 compression that makes 500 flywheel horsepower and 460 lb of torque. Can I run this on 93 octane? should I mix with 116 race gas? or should I just buy some 104 octane booster and drop that in everytime I fill up?
thanks
Had 11:1 on pump gas with no issues if built for it. Cam and chamber have alot to do with it. 12:1 is really pushing it. Reverse cooling (cooling the heads then the block) would probably let you get away with it but would require more work than its worth.
12:5:1 will be too much for pump gas if your going to have a some what aggressive tune and drive it daily. Personally i wouldnt spray on an 11:1 motor without a little 104 octane just to keep things safe. Just my opinion im sure people here have done both.
No way. Not unless the pump you go to says "trick" on it. You can get away with 11:1 with a big block but not a small block. 10:5 is really pushing it, in the summer especially. Any time the motor sees any combination of heat and load it will detonate.
5.0 HOtrain said:
My 418 is 11.25:1, runs good so far on 93 pump gas, 29* total timing.
mike.
A little over the 11:1 and you can do it with less timing but then you are defeating the purpose of the compression.. Ie less timing less power.. I just think I would rather have 11:1 and run 36 deg.. and let it scream.
:stupid: Bill is right 100%, and machining the chambers to lower the compression isn't always the best thing for flame travel, quench, etc...
Since you have O2's you would need high octane unleaded gas which is $4-$6/gal
12.5 is just too much. the cam and head type have a big effect on it. it can be done but a lot of precision measuring and machining must be performed.
i would not go over 11.0. even then it requires a lot of precision machining and measuring.
when going to high compression the quench ht. becomes very important.
