  • SN95 4.6L Mustang Tech
Cant figure this out
  • Thread starter Thread starter 99gsx
  • Start date Start date Mar 28, 2010
9
99gsx
  • Mar 28, 2010
I have a tapping noise coming out of my engine. It is there %100 of the time but gets loud once the engine heats up and gets louder as the rpms increase.
I checked for loose plugs, loose chains, bad lifters, I thought maybe the head might be messed up so I swapped heads (had an extra set). There isnt any metal in the oil, the oil isnt low, there isnt an exhaust leak from the head-headers, there isnt anything that fell into my oil pan, its not a pulley hitting anything. I had a compression check done and there all the pistons read pretty much the same. Im stumped.
Im gonna take a video tomorrow and post it as well.
E
e8597cobra
17
lancaster pa
Mar 28, 2010
  • Mar 28, 2010
k i have had a 4.6 sohc in the past. i had the thing blow on me going down the highway. my problem was the timing chain guides. they wear out after a bit and the chain slaps ageist them. they are made of plastic and are held in by 2 10mm bolts, also there are chain tensioners that also go bad but the taping started off soft then grew louder over time i hated the block so i ran it to the ground. i would look there first if all else fails there is always the oil pump in the front but i doubt that's the problem. and worse case is it could be the piston slap or a internal problem. i will watch the vid when you put it up its really hard to diag a car when you cant see it lol.
9
99gsx
  • Mar 28, 2010
Im trying to upload a vid but it wont let me upload vids off my phone. Im gonna try and get a video camera. If it is my chain guides couldnt I just take them out?
trinity_gt
3,125
81
99
Canada
Mar 28, 2010
  • Mar 28, 2010
Rod bearing.
nyuk98gt
1,427
Chesterfield, MO
Mar 28, 2010
  • Mar 28, 2010
99gsx:
Chain tensioners?
When did the knocking start? Was it right after a WOT run? Has the oil level ever been low? More details, please. (Let's hope it is not rod knock but trinity_gt might be onto something.)
Chris
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
