  • 1994 - 1995 Specific Tech
Can't find the keyless entry module
  • Thread starter Thread starter jwater7
  • Start date Start date Nov 17, 2004
J
jwater7
104
  • Nov 17, 2004
2 questions:
Well, I finally got my drivers-side door switch in, and did the old "lock the door, lift up on drivers-side door handle, and check to see if dome light turns on" test.
It does in fact turn on, so it makes me think that I've got keyless entry...however, I can't find the module.
Someone said that I should check inside the trunk under the "carpeting" by the rear lights, and also check by the drivers' feet. But I have not seen it.
1) Where could it be, if I even have one? If I had some wiring diagrams, I could trace the wires...
2) after a while, the dome light shuts off (like I've heard it should), and will turn on with a "door open" or "handle lift". However, if I leave the car for a while (like overnight) and come back to it, the light will not turn on again until I either turn the headlights on, or turn the key to the on position. Any ideas?
Thanks.
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Nov 17, 2004
  • Nov 17, 2004
The module is just behind and above the rear driver side wheel well. You'll have to pull back the trunk liner on that side to see it.
J
jwater7
104
  • Nov 17, 2004
aha, I found it...
Now I guess I've got to get a remote...
still no ideas on the dome light shutting off?
Thanks Rootus
J
jwater7
104
  • Nov 17, 2004
anyone have the FCC ID for the remote?
nm, this is probably a separate thread...
J
jwater7
104
  • Nov 18, 2004
ok, so since after a thorough search, I coudn't find any pictures of where it was, and it's a bit hidden...I decided to attach a picture of where the keyless entry module is, and what it looks like...so here it goes..
<IMG SRC="http://img59.exs.cx/img59/2539/IM001766.jpg" width=500>
J
jwater7
104
  • Nov 18, 2004
you've also got to be smarter than the dang plastic bolt that attaches the plastic mount, so here's a picture of it to help you out.
<IMG SRC="http://img64.exs.cx/img64/2567/HPIM0213.jpg" width=500>
J
jwater7
104
  • Nov 18, 2004
Still confused about the dome light though, any ideas?
J
jwater7
104
  • Nov 18, 2004
I want to be able to remove those pictures from "my attachments" but I think they're quite useful for the next person that can't figure it out...does "inlining" the pictures, like i've seen on other threads, save them perminantly?
NM, okay, I see how everyone is doing it, they're off-site images...I'll have to set them up somewhere...
BUT, still have problems with the dome light issue...
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
