Can't identfy vibration
  • Thread starter Thread starter mhjo
  • Start date Start date Sep 11, 2011
  • 3
First Prev 3 of 3
Slobin3d
246
17
38
Nov 2, 2011
#41
  • Nov 2, 2011
  • #41
mhjo said:
What they also don't know is that my lawyer har a '67 convertible, and he regrds this as A VERY SERIOUS CASE
mhjo
490
Oslo, Norway
Nov 4, 2011
#42
  • Nov 4, 2011
  • #42
Now that the Driveshaft is fine, I am back to where I started. (OH, yes, I had the wheels balance checked today)
When test-driving today I tried to pull the car from "D" to "N" in 40 mph when I noticed a small vibration. The vivration was still there in "N".
Is the harmonic balancer in the engine, or something in the AOD ???
bikefreak600
157
rochelle IL
Nov 4, 2011
#43
  • Nov 4, 2011
  • #43
harmonic balancer is on the front of the engine. round chunk of metal that the crank pulley bolts to. if vibration is there rolling in neutral its deff not engine related.
check all the bolts for the transmission mount & crossmember, also look at the rubber part of the trans mount. if its torn that would let the tailshaft of the transmission wobble. that could cause a vibration.
also check to see if the front yoke of the driveshaft is fits tight (no wobbles) on the transmission tailshaft (or inside the trans hole). IF that doesnt fit right or is loose thats your problem.
if that isnt the problem, then all thats left is the rear end. hope you figure it out
Slobin3d
246
17
38
Nov 4, 2011
#44
  • Nov 4, 2011
  • #44
in an open road, get up to speed and in neutral shut the engine off. If it goes away, engine issue.
M
mycoses
18
#45
  • Nov 10, 2011
  • #45
Have a vibration issue with my 71 tang. The 40 year old trans mount had collapsed the rubber so that the metal part of the trans mount was resting on the metal cross brace. Every vibration in the drive train went right thru the body and shook the whole car. A new trans mount eliminated most of the vibration. The engine and trans are not supposed to have any metal to metal body contact. The rubber in the engine and trans mount prevent metal to metal contact but eventually wear out. At one point I thought the vibration was the rear third member which I had rebuilt but did not get better. The differential specialist told me differential problems cause noise not vibration. I also had the rear axles spun on a lathe to check for bent axle but that was ok. Also could be the torque converter wihich also has to be balanced. Good luck.
mhjo
490
Oslo, Norway
Apr 13, 2012
#46
  • Apr 13, 2012
  • #46
Car is out og winter garage, and I am back at my problem. Last check by guru-mechanic concluded that the vibration is there at idle (at different rpms), and problem started after AOD swap.
He hinted that it could be caused by faulty converter in AOD. Anyone experieced with this?
wahoo23
63
Parker, Colorado
Sep 30, 2014
#47
  • Sep 30, 2014
  • #47
96 DOHC Cobra said:
What flexplate did you use? The swap requires a conversion type flexplate because the 5.0 that the AOD came from and your 289 are not balanced the same. The C4 flexplate won't bolt up to the AOD converter. The AOD flexplate will bolt right up to your 289 crank, BUT will cause vibration due to the balance differnce.
I am also having vibration issues since my AOD swap. Vibration happens at all times, even in park, leading me to believe it is a flex plate mismatch. You mention that the 5.0 flex plate will cause vibration (I have a 289/302), the C4 flex plate won't fit, and the AOD flex plate will fit but will cause vibration. My transmission guy claims there is only one flex plate that will work, and it is an AOD flex plate. What flex plate do I need?
  • 3
First Prev 3 of 3
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
U
8 Years of Vibration leading to engine knock?
  • UpgradeXP
  • Apr 14, 2025
SN95 V6 Mustang Tech Apr 14, 2025
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
