Can't Pull Codes!!
  • Thread starter Thread starter Hoffman
  • Start date Start date Sep 29, 2004
H
Hoffman
27
  • Sep 29, 2004
Just bought an 89 LX 5.0, The check engine light stays on all the time..
I Jumped the Self Test Input and SIG RTN terminals, and hooked up my test light, but nothing. The Check Engine light wont flast, and the voltmeter method won't work. And yes I did hook up the voltmeter to the STO output to positive battery terminal. Any Ideas?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 29, 2004
  • Sep 29, 2004
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Use the diagram above and check the resistance of the wires that run to the self test connector. If they are all less than 1 ohm, either the computer is bad, you have some bad connections on the black/white signal return wire, your test proceedure was incorrect, or the computer is bad.
Check the resistance of the black/white wire to battery ground. If it is less than 1 ohm, it is good. If it is more than 1 ohm, the black/white wire has bad connections or a broken wire. Always take resistance measurements with the circuit powered off.
Some help on the test proceedure...
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/article...c-iv_codes.html
IF your car is an 88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart .
jb89coupe
416
CT
Sep 30, 2004
  • Sep 30, 2004
Take a look at your self-test connector. Hold it so the row of 2 ports are on top and the row of 4 are on the bottom. Try running a wire from the port on the upper right directly to battery negative. Now do the same thing with the self-test input (the one that's hanging off by itself right next to the self-test connector) - jump it to battery negative. Put your car in nuetral, turn the key on (don't start it), wait a few seconds and see if your check engine light starts flashing.
If this works, you have a blown ground circuit in your computer or the computer ground is bad. You can check to make sure the 2 black wires going right to the battery negative terminal (wired in to the connector along with the thick black wire) are clean, but it's usually the circuit that goes.
Let me know if that works.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
