cant remove pinion gear from explorer 8.8 ??
  • Thread starter Thread starter slick_nick
  • Start date Start date Dec 13, 2008
slick_nick
20
  • Dec 13, 2008
cant get the pinion gear out of an explorer 8.8 at the junkyard. i got everything else out but that. it should just slide out right? if your looking at it from the drive shaft side you can see the big washer with the roller bearing behind it. is there something else that holds it?? thanks for any help.
P
PAzYearazzUP
Banned
Dec 12, 2008
33
  • Dec 13, 2008
You have to draw the pinion into the bearing with the crush washer and the torque wrench on the initial crush so the pinion is lined up or say it has to crush that washer to set the pre-load on the torque to drive shaft spline. You know, the X to Y can only go do deep is the shim and all that.
So, you more or less need to hammer or press out the pinion out of the bearing, is I think that's the same as a Dana is standard ring and pinion assembly.
slick_nick
20
  • Dec 13, 2008
so i guess ill have to use a bigger hammer
1987stangman
684
24
  • Dec 13, 2008
Removing the pinion nut and taping the pinion from the other side should get it out no problem. You did remove the nut, right? Are you removing these gears to put into your mustang's 8.8?
slick_nick
20
  • Dec 14, 2008
yes i removed the pinion nut. ive beat on it pretty good. just pullin these out to sell.
Beasty306GT
671
Oxford,Mass
Dec 14, 2008
  • Dec 14, 2008
what gear ratio are they
slick_nick
20
  • Dec 14, 2008
V
vadim
57
  • Dec 14, 2008
sorry to get off topic, what year explorer are these in, sound like a cheep way to upgrade mine in my stang.
slick_nick
20
  • Dec 14, 2008
i believe its a 98. i paid $25 for the gears,just need to get the pinion gear out. just find any year explorer with an 8.8 in it.
V
vadim
57
#10
  • Dec 14, 2008
  • #10
right on, thanks for the info. next time it's free parts day i know were i'm going be grabbing a pinnion and ring gear from.
1987stangman
684
24
#11
  • Dec 15, 2008
  • #11
You get what you pay for!
D
Deleted member 87397
Dec 16, 2008
#12
  • Dec 16, 2008
  • #12
I had to smack the hell out of mine with a three pound hammer to get it out, but unfortunately I damaged the threads where the pinion nut goes. If you are going to be smacking on it put a block of wood on the end and hit the piece of wood.
M
moostangvert
47
#13
  • Dec 16, 2008
  • #13
or you can put the pinion nut on the pinion and then smack and run the nut back out. no need for wood
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
  • Mindseye007
  • Aug 16, 2026
Mindseye007
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
