  • 1994 - 1995 Specific Tech
Cant see timing marks.
  • Thread starter Thread starter The Green GT
  • Start date Start date Nov 3, 2006
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Nov 3, 2006
  • Nov 3, 2006
I was checking my timing. But how the hell do you see the marks? I ran some chalk on the HB. I can "see" them but I cant get at the proper angle to see the one in the little window when the light flashes. It looks like you have to take the fircking alternator off to see it.
1TallMF
955
Montreal
Nov 3, 2006
  • Nov 3, 2006
haha I know what you mean. Seriously, it took me like 15 minutes to finally get the right angle the first time. The only spot I was able to put the light was right next to the upper rad hose, and if you look very very carefully you should be able to see the timing pointer from there. The only way is to keep trying, you'll get it eventually.
T
tjh566
608
Northern Va
Nov 3, 2006
  • Nov 3, 2006
yeah stand on the passenger side of the car and look by the hose as mentioned above, its a very small area where u can see it.
blksn955.o
3,263
st.louis mo 314
Nov 3, 2006
  • Nov 3, 2006
I painted my HB with some model paint, Painted the 10* mark green and the 14* mark red. helps alot.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Nov 3, 2006
  • Nov 3, 2006
i stuck thin piece of painters tape on mine, as said aim the light from the passenger side. ive hit the belt a few times with the tip of the light, also make sure all the wires for the light stay away from the belt
HISSIN50
34
129
Nov 3, 2006
  • Nov 3, 2006
Agreed. I use a silver Sharpie to fill in the lines from 8-16*, and fill in the number 10 too (makes the point of reference easier to pick up).
I think I almost hit the nose of my timing light into the alternator pulley when I have it where I can see. It's kind of a PITA.
Good luck.
The Green GT
1,269
Louisiana
Nov 3, 2006
  • Nov 3, 2006
I cut the light up a little on the blet. But i got it a few hours ago. Its set at 14* with no pinging.
I was at my friends house and his dad wants to try out my wheels on his '06 GT. Will they fit? Its just the backspacing that different right?
T
tjh566
608
Northern Va
Nov 3, 2006
  • Nov 3, 2006
i think that they would stick out a little far but they would work, not sure tho, someone confrim this.
M
Mustangsupra
26
  • Nov 3, 2006
We looked down from about where the upper radiator hose is, didnt really have any problems. The only problem we had was we marked the wrong spot.....
oh and we used a white crayon....
jeremy
JDS95GT
427
Nov 4, 2006
#10
  • Nov 4, 2006
  • #10
Are you trying to look through the little circle? I think the actual pointer is the straight line above the circle. Someone please correct me is I am wrong.
Dave
urban96
3,464
Syracuse, NY
Nov 4, 2006
#11
  • Nov 4, 2006
  • #11
Dave
yup yup, i was confused about this also before. its at the end on that straight edge
urban96
3,464
Syracuse, NY
Nov 4, 2006
#12
  • Nov 4, 2006
  • #12
Dave
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
