Canton Oil Pan
  • Thread starter Thread starter geordie
  • Start date Start date Mar 31, 2005
1 of 2 Next Last
G
geordie
576
  • Mar 31, 2005
Per my previos thread (now sadly history), I'm thinking about installing a Canton Oil Pan 7 quart as part of my engine strip down. Previous a couple of guys said that they liked the product and it provided superior oil pressure when cornering over the Cobra T pan which I now have.
On guy, and I forget his name, warned me that I would have to spent a good deal of time cleaning the pan, paint stripper, garden hose, compressed air. This really confused me. Are they not clean when you buy them?
Who stocks Canton Racing products?
302 coupe
1,952
Macon, Ga.
Mar 31, 2005
  • Mar 31, 2005
the sheetmetal pans are phosphate coated and have no maching done (other than the drilled holes, or are they 'punched'), so I don't know what that guy meant either. I'd maybe blow it out with some compressed air, just in case some dust/debris got in there during packaging, but it should be pretty clean.
G
geordie
576
  • Mar 31, 2005
I'll hold on and see if the original guy re-reads the thread and is able to explain.
allcarfan
The Answer Man
2,458
North Atlanta
Mar 31, 2005
  • Mar 31, 2005
7qt pans (chrome) can be bought on Ebay for less than $100. They also come with a pick up. They are nearly identical to the canton pans.
67GTA-FB429
777
Tri-Cities, Wa
Mar 31, 2005
  • Mar 31, 2005
You should wipe it out with a degreaser (wax/grease remover works well, or brake cleaner). Just make sure it is clean. that is what I did with my canton pan last summer.
thehueypilot
1,084
Medina,Tennessee
Mar 31, 2005
  • Mar 31, 2005
If you are running a girdle you might have to slightly reshape it with a hammer.
G
geordie
576
  • Mar 31, 2005
Not sure what's in there yet. I'll have a better idea when I remove the old pan this weekend.
65Mustang2+2
118
Connecticut
Mar 31, 2005
  • Mar 31, 2005
I can walk to Canton, it's across the street from my house!
Billgear
500
Concord, CA
Mar 31, 2005
  • Mar 31, 2005
All the Canton pans i've seen have been pretty clean. Like any product going on a engine, a good wiping/blowing out isn't a bad idea.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Mar 31, 2005
#10
  • Mar 31, 2005
  • #10
That guy was probably talking about the pan rail on the engine, not the oil pan itself.
67GTA-FB429
777
Tri-Cities, Wa
Mar 31, 2005
#11
  • Mar 31, 2005
  • #11
Are you putting the new pan on while the engine is in the car? If so, good luck. I did that last year, what a nightmare.
G
geordie
576
#12
  • Mar 31, 2005
  • #12
My engine is out of the car. So I'm hoping for an easy install.
67GTA-FB429
777
Tri-Cities, Wa
Mar 31, 2005
#13
  • Mar 31, 2005
  • #13
are you using bolts or studs? If I could do it over I would use studs.
bnickel
5,640
lubbock, texas
Mar 31, 2005
#14
  • Mar 31, 2005
  • #14
i think maybe he was trying say something about how to prep on for paint, the process you describe sounds about right to get the paint to adhere to that type of coated pan
G
geordie
576
#15
  • Jun 15, 2005
  • #15
Canton oil pan - Ford dipstick ?
With the Canton street type oil pan can you still use the normal Ford dipstick through the timing chain cover installation?
U
usedtobe 67p51d
208
let's tear up golfcourses and build race tracks!
Jun 16, 2005
#16
  • Jun 16, 2005
  • #16
original guy here.
they cut and weld an oe pan to make up a "T" pan
the welded joints need to be cleaned up bigtime
mine took about 1 hour or so
as far as oil control it works SO much better than a cobra T pans the baffels in a cobra pan are only side to side like this l l
cantons baffels or trap doors are in a <>
diamond around the oil pickup
I had oil presure issues with the cobra t but with the canton pan I've had zero issues oh and there's a BUNG to added so you can add a oil temp gauge ANYONE interested in a fast '67 fastback? mine can be had
thehueypilot
1,084
Medina,Tennessee
Jun 16, 2005
#17
  • Jun 16, 2005
  • #17
I was able to but the dip stick barely hits the front baffle. I have to work it around a little to get it to skip past it so that it wll seat all the way. If I had it to do over again or the next time I drop the pan I will notch it so the dip stick clears the baffle.
Bullitt
Packin' Heat
2,743
Houston, TX
Jun 16, 2005
#18
  • Jun 16, 2005
  • #18
i have pan and have nothing but good things to say about it.
i'm running a front mount dipstick and haven't ever had it hang up on anything.
washMO66
1,000
Washington, MO
Jun 16, 2005
#19
  • Jun 16, 2005
  • #19
true, on mine I had to bend one of the baffles on the side down slighty to get it to fit. The fit and finish on the Canton is excellent and it has never leaked once installed................until after two years one of the factory welds starting seeping slightly on the bottom "T" part.
Someone said engine harmonics could have caused it, but seeing that my engine was 100% balanced during the build I contribute it to just a faulty factory weld.
All that being said I will probably go with a Canton again as on the curves my oil pressure stays high and like I said the fit and finish really seemed good.
66P51GT
721
Cerritos, CA
Jun 16, 2005
#20
  • Jun 16, 2005
  • #20
Jim, you're selling? Are you looking to start another project or are you getting out all together? If you have any parts laying around, let me know what you have and I'll make an offer. As for the beast, you should get some good coin with all you have put into it. You definitely have a wicked ride.
-Charles
1 of 2 Next Last
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Let's talk chassis/under carriage cleaning, coating and painting
  • 2000xp8
  • May 1, 2023
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 3, 2023
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
