You lose the use of that sensor unless you want to try to modify the pan... Just clip the wires and tuck them up in the harness.
Use a Fel-Pro OS34508 gasket, with a silicone bead up fron and rear on the pan, do not use the stock pan rails either, BLUE loctite the bolts. I have been building with the Canton stuff for years...
Why not drill a hole in the pan to retain the use of the sensor?
The pan hasn't been installed yet has it?
jason
I found the Cantons leaked when using the rail supports, the Cantons did not have smooth rails like the stocker, they had embossments every inch or so.
Now with that being said I just got in a shipment of 15-620S and they now have smooth rails, so the supports should work. I also use ARP bolts which are not long enough for use with the supports..
Rick
Thanks everyone!!Iwas reading other post about the blue 1-piece gasket with the metal inside. What is the best the 4-piece or the 1 piece?thank you.
