Capri struts
Only 4 sylider struts, 87- 93 would fit. 5.0 GT LX struts would not fit your wider -86 spindel . The 87 and newer 5.0 spindles are 2-3mm to tight for fitting at the spindlebolt area.
Picture of mine, Strange strut, after mod. Cut and weld. Move the plate from the inside to the outside, and weld. Then it fits fine.
It wasnt the front I had problems with. It was the rear. The upper mounts are different. The '87-93's have eyelet sorta mounts. Where as mine is just a straight shaft with a nut on top. Or did someone send me the wrong rear's???????????????
Mine were like you have. I had to cut off part of the bottom of the shocks though. The eyelet for the bolt stuck out on each side and my car just has a mount for a shock with no extended eyelet. A hacksaw took care of that.
