CivicEater said:
Who can test my TFI and coil? Autozone? I cant find an adapter for the fuel rail around here anywhere and the one I was using had the center pintle break so I have to still adjust FP right. Would the TPS cause a constant speed miss? I was under the impression it was more of an idle thing
dude i feel so bad for you if you were in texas, i would drive to come clean out all your bugs one weekend.
and texas is BIG
set your tps at .996-.999. you do this by getting a multimeter (you can borrow one form a parts store.) put the ground on a good ground.... the strap to your hood insulator.
and stick the other one into the wires.
do this with the car in the a/c position but not running.
there are 3 and one will have a constant vultage. the other will range up to 5volts as you open the throttle blade.
at the idle position, it should be in the .996-.999 range. losen the screws and turn it until you see the multimeter in this range. It may require removing the IAc so you can take it off and drill out the holes on the tps so it will turn far enough to get to the correct range.
ABOUT YOUR AF GUAGE
i have one too. those guages are based on votage and only read at WOT. you can actually KIND OF tune off this if you know what voltage is what A/F
remember this. the stoich signal is 14.9 not where you wnat it to be. you want it well into the rich area of the lights.
my a/f was 13.1 on the dyno and it reads second to the last green square at WOT.
most likely your pickup is bad. or "stator"
you cant replace this at home. you must remove the distributor and have a press to remove the gear to slide the shaft out and put the new stator in and then put it back on and nail the pin in.
you might want to just invest in a new distributor or make friends with a tech at some shop.... ford techs make really good friends
dont take your tfi to autozone. they will 99% of the time tell you its bad and sell you a new one. they told me mine was bad and it wasnt. it was the wire form the tfi to the distributor that had melted. check that connector BTW where it connects. autozone doesnt have the stuff to properly test the tfi iin real world situations.
oreileys > autozone
and what is wrong with your afpr? i have an extra one here.
I hope my post is helpful unlike my usual criticising arrogant posts.
