car backfiring
  • Thread starter Thread starter blackjackbender
  • Start date Start date Nov 8, 2005
blackjackbender
36
  • Nov 8, 2005
finally got the car started back up after pulling it to clean up the engine bay.
i put in a new cam and timing chain. the engine runs but when i rev it up it backfires. My boss was helping me out and we got the timing set good but he was telling me it was probably a rocker adjustment or carb problem? sound right or have any suggestions yo sstop the back firing?
thanks
Ty
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Nov 8, 2005
  • Nov 8, 2005
Does it back fire through the carb or exhaust.
You did put the timing gears and chain on correct, right.
68 Coop
104
Mesquite, NV
Nov 8, 2005
  • Nov 8, 2005
How did you set the timing this time???
M
my66coupe
1,134
Arizona fountain hills
Nov 8, 2005
  • Nov 8, 2005
12* of advance.....make sure. Check your timing first....if timing doesnt fix it....move to the next most obvious clue...your timing chain and cam.
Mike
blackjackbender
36
  • Nov 9, 2005
im 99.9 percent sure the timing chain is alligned right.
it only backfires once and a while when trying to start it and it back fires through the carb. the timing was set by ear but ill try and get a timing light to get it perfect. im gonna try everything before i try the timing chain seeing that everything is installed and painted nicely. im 99.9 percent sure its not the timing chain though. starter went to **** so im gonna have to get a new one before i can go any further. worth going for a hi-torque convertor? may have to make that long 5 minute drive to NPD to get a new one.
thanks for the help,
Ty
krash kendall
1,258
Aldergrove, B.C. Canada
Nov 9, 2005
  • Nov 9, 2005
Firing order.
D
dans70stang
23
  • Nov 9, 2005
i would say the timing chain, but i have also had a few backfires myself when the distibuter was not timed right, and even if the vaccum advance is off it could also add to ur problems.
Pakrat
3,843
Currently: NH Originally: Rhode Island (and all po
Nov 9, 2005
  • Nov 9, 2005
If you are still running points check the gap, heck even if it's a pertronix check the gap, a little off will cause a back fire for sure, especially if they are dual points.
BTW, timing the car by ear is just fine, so long as it is not pinging you should give it as much advance as it likes. It may end up at 12 or 13* BTDC as being optimal but no body can just tell you what to set it at, heck stock setting is 6* BTDC so what does that tell you.
blackjackbender
36
  • Nov 9, 2005
krash kendall said:
Firing order.
already fixed the firing order.
i will double check the gap on the petronix and keep on checking the timing
i dont want it to be the timing chain
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
