Car cranks but won't start
lancec2c30
570
Washington
I just finished up running part of the engine harness into the inner fenders, to clean the bay up some.
But now with it all back together, the car won't fire.
I went through the checklist, but it didn't help me find the problem.
So with the key on, I do hear the fuel pump prime. I also verified 12v at the injectors red wire.
At the plug going into the top of the coil, I get 12v at both the red and tan wires when I test them to a ground. And when they are jumpered together, I don't get any input to the test light whatsoever.
I pulled the coil wire off the distributor and put a spark plug in it, held it to a ground, and couldn't see a spark.
I checked the top wire of the TFI module, with the key on it reads .5V. While cranking, it doesn't change.
Also tried starting with the spout removed, no luck there either.
I'm not really sure where to go from here. :shrug:
After looking further, I don't think the injectors are firing either. I can turn it over for a good 20 seconds straight and pull a plug. It's dry and you can't even smell fuel. I also plugged in a spare injector and did the compressed air and water test. Couldn't see any bubbles come from the injector tip.
I am about fed up. No fuel or spark.... I figured maybe the repair I made to the burnt trace on the back of the ecu had come apart. Nope still fine, so I insulated it in case the jumper I made was grounding out, still no change.
So I pulled the 3 grounds you can get to, (firewall, ecu to batter, and a 3rd) scuffed them and re-attached them. nope.
I'm about ready to pour 5 gallons of gas on this pile and just torch it off.
Getting nothing, but turning over... Check those "salt-n-pepper" shakers in the rear of the engine bay. If they're disconnected, you'll get nothin'... but an engine turning over. Problem is, there are so many possibilities that it won't be well diagnosed on the internet.
Did you go through all the checklist steps or did you pick and choose what you wanted to test? Most of the people who don't succeed with the checklist simply don't follow it step by step.
If you did all the steps, you would have found step 1 B & C, which describe your current situation pretty good.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 19-Jun-2009 to clarify ignition switch & coil power states.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:…
Sorry, the AutoZone wiring diagram links no longer work. You can navigate to the diagrams yourself via AutoZone.com | Repair Info and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
I wanted to verify it was the pip sensor by dumping the codes, but when I hooked up the jumper and test light, I gt a click and the fuel pump primed. Then the light went out, and that was it.
I tried jumpering the single grey connector to ground, no difference.
That almost sounds normal... Once it's primed, without the engine running, it should stop. It's been way too long since I had that setup though, so maybe someone can give you the (correct) answer.
A bad PIP sensor does not always set a code. The noid light test is the way to test the PIP.
The 11 code is often very faint and easy to miss. Fix your PIP problems first and then chase other rabbits.
I'll plan to replace the pip sensor I guess. But I wonder how it would have went bad in the first place. The car has not giving me any trouble at all for the last 7 months, I pull it in the shop, re-route wires, and go to fire it back up.
I don't want to go through all that work to replace that sensor, and have an underlying problem short it out or something.
And not being able to get the computer to go into diagnostic mode at all worries me.
Is there any way to differentiate a faulty pip sensor from wiring related to the pip sensor? Checking resistance or something?
I'm going to buy a reman. distributor tomorrow, but the fact that I moved around the whole engine harness makes me think the PIP sensor itself isn't the problem.
The PIP sensor wiring is so short that it isn't a consideration. The TFI wiring can be tested end to end with a DMM or ohmmeter. Keep in mind that the IDM wire has a 22 K Ohm resistor it it, all the rest of the wires should read less tha 1.5 Ohm end to end. See the following site for diagrams and TFI module information.
(website host) for help on 86-95 5.0 Mustang wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 88-91 5.0 Mass Air Mustangs
Complete computer, actuator & sensor wiring diagram for 91-93 5.0 Mass Air Mustangs
Complete computer, actuator & sensor wiring diagram for 94-95 5.0 Mass Air Mustangs
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
I tested with a DMM from the TFI plug to the pin-out at the ecm.
All wires checked out at .3 ohm except for the tan/yellow. It was 21k because of the resistor.
So I would assume that I don't have any faulty wiring going to the TFI. I'm gonna call the parts store and order my dist. then.
