After doing the upper/lower injectors, maf, TB and headers the car started right up, and ran rough, but ran. I started it many times while doing the timing and it started effortlessly. Then, I was driving to my friends garage to change the oil and use his air tools to tighten up the exhaust when it started bucking real bad and running REALLY rough. I went to the side of the road and it just turned off and wouldnt start. Eventually i got it started by holding it at WOT and it would run VERY VERY rough and barely driveable. Back at his shop we put it up on a lift and noticed oil dripping from the back of the block. After putting the car back down i noticed it was the pcv valve, as it had popped out for some reason. The car STILL wont run however. We were playing with the timing, he had an extra MSD cap and rotor so we put that on, and still no luck. Once we get it started by holing it at WOT it seems to run half decently, though still rough. Anyone have any suggestions as to what might be wrong? i checked all the vacuum lines i can see and im getting 20 in of vaccume at around 1200rpms. The car just wont stay running though. Any help would be greatly appreciated!
did it with # 2 and 3. same symptoms
