Car dies in motion when weather is more then warm
killer's88gt
Texas!
Here's the deal. This car runs BeAuTiFuL, so long as the weather is cool, but as it has been hot in TX, it died in motion. I check the inertia switch, I had my laptop back there, no good. After the car has time to cool to 140-150, still no good. I checked the inertia switch again, jiggled the wires to it, get in, try it, and it starts.
I was "sans tools/code reader" and on my way to the airport. It died 2 miles later, pulled over, jiggled the wires, and I made it the remaining 3 miles to where I park.
If anyone knows:
1. Why does this happen when outside temps are 80+? (yes, it has happened before, but I don't drive it alot-bike gets better mpg-too lazy that day to load the bike)
2. Why does this not happen when temps are cooler?
Thanks
Many temp related problems are the result of a TFI module that is defective.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. There is a separate blue fuse link for the coil which can open up and rob the coil of power.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
At the risk of sounding like a complete cracker, and this hotel internet SUUUUUCCCCKKKKSSSS, all I found about TFI was a "gray dizzy" something. What does TFI stand for, and where is it, minus gray dizzy crap. Yes, I do have limited manuals at home that would explain TFI, but that is not where I am, and if I was, I would be working on either my wife, my car, or my master bath.
thanks
OK. :shrug:
The TFI = Thick Film Ignition. It is the grey plastic module on the side of your distributor.
Parts stores can bench test it - and JRichker is correct about it showing its age when they get hot and are on the outs.
If you go down the parts of his checklist that apply to you, you can isolate the issue. For instance, if you have spark as it dies, the TFI would seem to be fine.
And all you need to yank codes is a jumper wire (hair clip, paperclip, etc).
Good luck.
