car dies
  • Thread starter Thread starter triostang
  • Start date Start date Jan 3, 2004
triostang
142
  • Jan 3, 2004
im driving and when im about to slam on the pedal, the car chokes i guess.
i try again and i slam on it and the car just dies... why?
crushnut
870
Oregon
Jan 3, 2004
  • Jan 3, 2004
Sounds like your carb needs to be tuned good
triostang
142
  • Jan 3, 2004
is that it? you sure?
crushnut
870
Oregon
Jan 4, 2004
  • Jan 4, 2004
It's a good place to start
RGS0907
429
New Jersey
Jan 4, 2004
  • Jan 4, 2004
Always start with the ignition. Everyone jumps right away to the fuel system, but playing the odds, it's always better to check out the entire ignition system first. Did you pull & read any plugs yet?
6Stang7
1,470
Livermore, CA
Jan 4, 2004
  • Jan 4, 2004
Sounds like a you have a problem with your floats. What kind of carb is it? When was the last rebuild on it done?
-Shaun
mdjay
Premium Sponsor
Dec 9, 2003
896
Las Vegas, NV
Jan 4, 2004
  • Jan 4, 2004
dies
Does it smoke when you are doing this?
triostang
142
  • Jan 4, 2004
no smoke, brand new holley 750, i'll check the ignition then
crushnut
870
Oregon
Jan 4, 2004
  • Jan 4, 2004
I'd still check that Holley, but thats just me
RGS0907
429
New Jersey
Jan 5, 2004
#10
  • Jan 5, 2004
  • #10
-Shaun
If if stumbles or dies making a left hand turn it could point to the float levels being too high.
6Stang7
1,470
Livermore, CA
Jan 5, 2004
#11
  • Jan 5, 2004
  • #11
I am not sure how the Holly's floats are set up, but I think what might be happing here (going on how Edelbrock's floats and float bowls are set up)l is that your floats are set too high; to the point were it is letting in just enough fuel for the car to run. What I think is that when he slams on the brakes, all the fuel in the bowls flys forward and up against the wall. Now, since all the fuel has been momentarily pushed forward, I see either the primary metering jets getting un-cover (your floats being set too high causes a low level of fuel in the bowl, if you had the normal level then there would be more fuel in the bowl which would still cover the jets, ever when the fuel flys forward), which means your engine would loss fuel until the primary metering jets get covered again; that the fuel flying forward and up against the bowl wall causes the float to rise, closing the needle and seat, stopping fuel from being allowed in; or both. I don't know if this is what is really happing, but this is just my guess. If I were you, I would re-adjust the floats and see if that solves it.
-Shaun
crushnut
870
Oregon
Jan 5, 2004
#12
  • Jan 5, 2004
  • #12
I thought he was talking about it happening when he slams on the gas, not the brakes. But i could be wrong
G
GaPonyFarm
663
Columbus, GA
Jan 5, 2004
#13
  • Jan 5, 2004
  • #13
You don't give much information to work with. Year, Engine, Tranny, would be helpful...
Generally... I'd say make sure your plugs, wires, points (if you got 'em) are good and set properly... Check the timing and finally.. depending on your engine you might be over-carbureted. Unless you have a really hot small block, a 750 cfm carb is too much.
6Stang7
1,470
Livermore, CA
Jan 5, 2004
#14
  • Jan 5, 2004
  • #14
Never though of that. If it is the gas, then it would be a totaly different problem. If it is, then I sounds like your accelerator pump is spraying too much gas.
-Shaun
crushnut
870
Oregon
Jan 5, 2004
#15
  • Jan 5, 2004
  • #15
I agree, that carb may be way too big for his engine.
triostang
142
#16
  • Jan 5, 2004
  • #16
fixed it, i thought i had tuned the carb but i had done it wrong the times i tried to fix it..but i got it right now lol
im not over carburated so carb isnt too big... the only thing stock is heads and crank
triostang
142
#17
  • Jan 6, 2004
  • #17
fixed it....some carb parts were crap
J
Foxbody trans swap
  • jimendo20
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
KRUISR
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
O
Keeps dying
  • Oscar_Picuco
  • Sep 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2025
squeak93
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
