CrazyCobra
I ment to mention your ride, sweet
, very clean, love the white cobra's, i'm runnin on boring old chromies
I'm convinced my problem (same as yours) is bumpsteer, how much lower is your car than stock? Check the angle that the tie rods are at, they should be nearly staight, more angle=more pron to toe in with any suspension compression, as when moving down an uneven road at a high rate of speed, more toe change=unpredictable, unstable, unwanted no input steering of its own.
Thats where my next change is going to be.
Good luck, I continue to whatch this post for any other suggestions
.I'm convinced my problem (same as yours) is bumpsteer, how much lower is your car than stock? Check the angle that the tie rods are at, they should be nearly staight, more angle=more pron to toe in with any suspension compression, as when moving down an uneven road at a high rate of speed, more toe change=unpredictable, unstable, unwanted no input steering of its own.
Thats where my next change is going to be.Good luck, I continue to whatch this post for any other suggestions
