Car Hates Gas
  • Thread starter Thread starter Dark_Phoenix
  • Start date Start date May 5, 2008
Dark_Phoenix
Oceanside California
May 5, 2008
  • May 5, 2008
Yesterday, I noticed I had about an eighth of a tank left so I pulled into a gas station to fill her up. I only tried to put in $25.00 , and by the time $18.00 worth was pumped, the pump shut off, and gas came pouring out. I KNEW there was NO possible way my tank was anywhere near full, but I still looked down in there. It wasn't, so I attempted pumping again ( just for the same thing to happen almost immediately ) . Not good for the car, or for me. I ended up pulling away with just under a half - tank because she just wouldn't take anymore...This is the first time this has happened, I know the tank itself is fine, so i'm flat out STUMPED. It's a 1965 Coupe that I'm restoring, and it's my first classic, but i've filled it up before many times. Is there a certain technique to this? ( I feel so stupid am I doing something wrong here or could it actually indeed be a prob. with the car?
Thank You for your help,
Chrystie
fvike
335
Mosjøen, Norway
May 5, 2008
  • May 5, 2008
I always keep the pump pistol as far out as I can, because I've experinced that when I put it all the way in, it will stop. By keeping it as far out as possible, the fuel can drain away before it stops the pump. And fill slowly when it's nearing full.
Dark_Phoenix
May 5, 2008
  • May 5, 2008
Thanks fvike
I figured I was probably doing somethink wrong ><
Tim65GT
1,149
West Texas
May 5, 2008
  • May 5, 2008
Was it a gas station you go to regularly? Some of the vapor recovery nozzles are more sensitive than others. Just ask any motorcyclists about gassing up and tying to top off.
70vert
722
Bay Area, CA
May 5, 2008
  • May 5, 2008
I try to fill up the Mustang like I do my motorcycle - pull back the pump "sleeve" vapor control device and fill up slowly. I have the same problem if I just try to fill it up, even more so now that I have the Mach 1 style gas cap - I can't get the pump at the right angle. Filling up a 22-gal tank "slowly" can be tedious, though . . .
68stang351
850
9
39
Savoy TX
May 5, 2008
  • May 5, 2008
I have to barely put the nozzle in, hold it sideways, and only pull the handle half way. If I do it any other way, gas gets everywhere. You might try that.
brianj5600
1,964
Middle TN
May 5, 2008
  • May 5, 2008
Another thing it could be is a bad float on the fuel level sender. Mine did exactly that when I got it. When I pulled it for a new tank the float had fuel inside it. It was not floating on top of the gas, but slightly lower giving false readings. Most Mustang resto places sell just the float. Be sure to buy a new o-ring seal for the sender/pickup. Mine was sealing, but hard and cracked. I would not take a chance on a possibly 40+ year old rubber seal.
You still have to be careful of the angle and how far you put it in though.
NasaGT
1,993
Virginia
May 5, 2008
  • May 5, 2008
You sound like my wife!
SadbutTrue
2,391
Thousand Oaks, California
May 5, 2008
  • May 5, 2008
out of curiousity, the 65-66 cars had 16 gallon tanks right? My gauge shows E early and usually only needs about 10-11 gallons to fill up, and I'm always guessing as to how much I actually have...
izzy jr
76
Abilene,TX
May 5, 2008
#10
  • May 5, 2008
  • #10
That sounds about right ^^^^^^^ I think the 68 or 69's had 18-20 gallon tanks.
68stang351
850
9
39
Savoy TX
May 5, 2008
#11
  • May 5, 2008
  • #11
I think they started the bigger tank in 69. I just bought a gas tank kit for my 68 and its a 16 gallon.
brianj5600
1,964
Middle TN
May 5, 2008
#12
  • May 5, 2008
  • #12
Check your float. http://www.mustangsunlimited.com/it...01&Category=Fuel&subCategory=&CatKey=EMUSTANG
68 fuel gauge maxes out at half
  • connella08
  • Sep 5, 2025
Classic Mustang Specific Tech Sep 8, 2025
connella08
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
