car is leaking!!!!
mustangking101
23
AZ
my 1994 im pretty sure is leaking for the oil pan because the gasket is bad...
i know its oil for sure because i have to put oil in my car a lot kinda.
so what all do i have to do to put a new oil pan gasket on?
do i have to remove my whole k member and **** or is there an easier way cause that is gonna take a lot of time...
people are saying i cant remove the pan just as is i would have to take out the k member so i neeeeeed some help thanks.
If you're positive it's the oil pan gasket, you have to pull the engine up to drop the pan. Some people have been able to lift the engine a little bit and snake a new gasket in, but it's hard work nonetheless. :(
A rear main seal leak will make it look like the pan gasket is leaking. And you could
be burning the oil your loosing... rings / valves.
Clean it up, take it on a short trip then look again...
if it is the pan gasket, depending on how bad it is, i would try and get some high temp sealant and spread it liberally long the block/pan/gasket area. i did that on both sides of my engine in the past on different occasions to stop a leak and it held good for a long while.
it's a bandaid thats for sure, but it saves you pulling the engine.
