car looks like its ridin a wheelie
04gtboy
83
Want to just lower the front.What would be the spring to make it sit level?Or even give it a little rack in the front.Will i still need c/c plates just lowering it a little bit?Its all stock right now dont want to lower it all the way around bad roads here just want a nice stance.
Well first of all why is it lower in the rear? I would fix the sagging in the back and get new springs front and rear. Probly be a good idea to get the camber/caster plates. Would suck to get everything back together then take it all apart again if you cant get it aligned. Roush seels just fronts or rears and theres a couple others. For a set of 4, can go Steeda or H&R, get some shocks/struts and I would highly recomend while you have the rear apart to swap in some boxed lower control arms. Check out Steeda or Maximum Motorsports websights.
