car not charging
  • Thread starter Thread starter coupecop
  • Start date Start date Feb 16, 2008
C
coupecop
166
mission texas
Feb 16, 2008
  • Feb 16, 2008
I'm having prob with the car not charging it had a new battery and the charger is working had it check don't know what else to check
HISSIN50
34
129
Feb 16, 2008
  • Feb 16, 2008
Huh?
What was tested and how was it tested?
Is the battery light illuminated while the car runs?
Is all wiring, including fusible links, intact?
C
coupecop
166
mission texas
Feb 16, 2008
  • Feb 16, 2008
The alternator was checked at oriely and the battery is new the bay light is not on will it have any thing to do that I changed the cluster
HISSIN50
34
129
Feb 16, 2008
  • Feb 16, 2008
If you interupted the switch circuit for the alternator (it runs through the amp light), this can cause the alt to not charge. A dynamic test would have shown the alternator having no output.
Does your amp light work? It should prove-out when you turn the key to accessory. If it never comes on, the bulb is bad or the circuit has been interupted and your alternator doesnt know that it needs to start charging.
Good luck.
04sleeper
2,674
14
89
Dallas, TX
Feb 16, 2008
  • Feb 16, 2008
Sounds like you did not put the cluster back correctly. If the switch circuit is not hooked up, (like JT mentioned), then your alternator will not charge.
You could always run power to the exciter wire on the alternator and see if charges.
Have you tested the voltage at the battery and see how many volts you are getting when the car is running?
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Fox Jump/start - Charging
  • PonyGTrider
  • Oct 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
PonyGTrider
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
F
Alternator Not Charging
  • Fri Guy
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2025
AeroCoupe
