  • 2.3L (N/A & Turbo) Tech
car not starting, plug wires marked before removal HELP!!!!
  • Thread starter Thread starter 90mustang4cyl
  • Start date Start date Oct 10, 2005
9
90mustang4cyl
  • Oct 10, 2005
I have a 90' 4 cylinder, single plug motor. I checked the plugs today and now my car will not start. It sounds like, when it does start, that the plug wires have been crossed, but I marked the wires before I started. Even the diagram in my Hayne's manual proved I marked them right. It felt like, just as it started to run, it would start turning the other way. It felt as though maybe a piston was traveling up and fired prematurely, forcing it back down against the direction the crankshaft was pushing it. Anyone have any ideas of what it could be??? Thanks guys.
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
Oct 10, 2005
  • Oct 10, 2005
Hm. Did you crack the ceramic on any of the plugs? Are the plugs all tightened down enough?
J
jgt58
92
Knoxville,TN
Oct 11, 2005
  • Oct 11, 2005
sounds like your timing is off. Did you put or move your distributor?
88stangmangt
2,332
Stafford,VA
Oct 14, 2005
  • Oct 14, 2005
did you take the coil wire back off???
big_tiger15
88
Arlington, Texas
Oct 14, 2005
  • Oct 14, 2005
See if you ripped one of the wires, and keep them away from each other. Might be crossing wires and firing another cylinder.
TurboFlush
1,984
Germany
Oct 18, 2005
  • Oct 18, 2005
you must of smacked the timming off or something. if the wires are how they were before and the manual confirms it then you should be good. spark gap?
I would normally say you got the timing 180, but you would of had to mess with the timing belt if that were case.
lets try this. from the vacume device that comes out of the distro (should be a spot to plug a spark wire into) go clockwise and put the wires in this order 4-3-2-1 make sure that first one goes to #4 the next one to cylinder #3 and so on.
you will find it, and then laugh. ;-)
TF
J
JB66
565
New York
Oct 18, 2005
  • Oct 18, 2005
Pull 1 plug wire at a time (using insulated pliers) and see which one doesn't affect your idle. Pull that plug and replace it.
TurboFlush
1,984
Germany
Oct 19, 2005
  • Oct 19, 2005
ahh, hell with the insulated pliers. hell with the pliers. ! LOL I just pull them off by hand! The jolt is garunteed to wake you up!!!!! :-O
its up to you.
always pull on the boot not on the wire. pull on the wire and you will end up buying new ones. if it wont budge, try twisting the boot, sometimes they bond to the spark plug. after twisting, it should pop right off.
TF
  • dan50
  • Jul 18, 2026
dan50
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
D
94 GT cold start takes a long time cranking. Help!
  • DeanS
  • Aug 6, 2024
1996 - 2004 SN95 Mustang -General/Talk- Aug 10, 2024
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
