Ok I just finished swapping in a 351w and am trying to start it for the first time...
Problem one. The Fuel pump won't prime when I turn the key. I checked all the grounds and everything, all look good. However... It does turn on if I pull the relay and use a jumper wire to jump the terminals. I don't have a test light or anything here as they are at work atm so can't tell if im gettin power at the control side of the relay.
Ok so I left the jumper wire in the relay so that the fuel pump is always on. Turned the key and still nothing. I am getting spark also so I know its not that. What else can I look for that would not let it start?
