  • SN95 4.6L Mustang Tech
car not starting ...
  • Thread starter Thread starter phoenix99
  • Start date Start date Apr 30, 2009
P
phoenix99
63
Quebec
Apr 30, 2009
  • Apr 30, 2009
Hi, i've a really strange problem with my mustang.
I've swapped my 4.6 2v for a 5.4 4v. I've swapped the PCM of my old GT(98) for a Cobra(97) with an sCT chip with PATS off.
I've drove the car for about 11 miles and then the car won'T start anymore !
I've fuel to the fuel rails, I've recharged my battery, I've even try to jump start it.
I've tried with my GT PCM, no luck. I were able to read a p1260, theft detection, I tried to clear the code but no luck.
I've double checked EVERY fuses, all of them are like new.
Anyone have any idea ?? I'm really confused about this problem ...
Thank you very much !!
blackink00
I missed a shift & stole Curt's money.
Mar 30, 2005
545
Tempe, AZ
Apr 30, 2009
  • Apr 30, 2009
p1260 is a pats code. pats is acting up
P
phoenix99
63
Quebec
Apr 30, 2009
  • Apr 30, 2009
but if I reinstall my cobra PCM with the chip, normally the PATS will let the car start ?
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Apr 30, 2009
  • Apr 30, 2009
are you sure the chip didn't come loose?
G
GT Tommy
190
  • Apr 30, 2009
You may want to check on this?
It wouldn't hurt to check on your crankshaft sensor. If your pcm does not receive a signal from it, your engine won't start. You may also want to check your wiring configuration. Some of the PCM wiring from your 4.6 may be a little different for the required PCM wiring for the 5.4. I would check the pin outs between the two PCM's. Good luck, Tommy.
P
phoenix99
63
Quebec
May 1, 2009
  • May 1, 2009
Thanks, I'll look for the crankshaft sensor.
for the wiring, it's from a 97 cobra.
the engine was running fine before this..
do you think a sensor can stop working just like that ?
Thanks again !
squeak93
2,325
401
164
Joplin, Missouri
May 1, 2009
  • May 1, 2009
All the sensors/connectors are the same. YOu will need to use the sensor for that motor/timing cover but the connectors are the same and they send the same signals. They do look different at times and have different legnths but plug in the same and snd the same signals.
That being said, a bad crank sensor will f things up in a hurry. Check to make sure no wiring got smashed or hot by accident.
G
GT Tommy
190
  • May 1, 2009
Another 4.6 to 5.4 Swap Out!
Not sure if you reviewed this thread. Lot's of info. Perhaps you can get some info here that may help. Worth reading, I would say. Good luck, Tommy.
5.4 N/A cobra project - Corral Forums
P
phoenix99
63
Quebec
May 6, 2009
  • May 6, 2009
well it was my crank position sensor who was dead
I replaced it and it started like a brand new car !
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Resolved 1996 PATS help needed
  • Bajaboy
  • May 21, 2025
SN95 4.6L Mustang Tech May 23, 2025
Bajaboy
C
99 mustang gt no signal to fire coils
  • Cerana04
  • Oct 4, 2025
SN95 4.6L Mustang Tech Oct 4, 2025
Cerana04
C
