Hi Stangnet,
I've research high and to try and find a definitive answer on the pats issue I am having. Would like to know if anyone has had similar problems before I start throwing parts at it.
1996 4.6L - 100% original been in storage since 2011 with 9k miles on it (for condition perspective).
Both keys have the same result: Car will start and run normally with key in one orientation. Insert the key in the opposite orientation and I will get the theft light flashing (car will fire up then die).
When leaving a key in the ignition and flashing, PATS will not give me a blink code. After it's timed out the theft light goes out and the car will crank over and die out.
Furthermore - If I have a key in the ignition in the "wrong" way with the PATS light flashing, I am able to take the second key and put it near the cylinder which satisfies the PATS system and the light goes out allowing the car to run normally.
It seems as if the key signal is weak.
Anyone have a similar problem?
