  • 1994 - 1995 Specific Tech
Car Shakes like Crazy!
  • Thread starter Thread starter Fordman302
  • Start date Start date Jul 20, 2006
F
Fordman302
Orlando, FL
Jul 20, 2006
  • Jul 20, 2006
It's been a long time since I have came here but I'm having a problem with the mustang. I was traveling to see a friend about 300 miles away. On the way I started to feel a little vibration and by the time I got there it was a serious vibration. The whole car shakes at speeds of over like 20mph. The weird part is that if I stay a constant speed around 50 or so, it will get really loud and then completely stop and it will be the smoothest ride ever until I slow down again. The two things I came up with was either the driveshaft got out of balance or maybe the harmonic balancer or something like that. Any info would be greatly appreciated!!
BlackVert
5,589
9
98
Bethesda, MD
Jul 20, 2006
  • Jul 20, 2006
those would be the first 2 things i'd check.
good luck and let us know
1TallMF
955
Montreal
Jul 20, 2006
  • Jul 20, 2006
my money is on a worn u-joint
94-302-vert
1,947
NE CT
Jul 20, 2006
  • Jul 20, 2006
does it happen starting at 20MPH regardless of whether you are in 1st, 2nd, 3rd gear? OR does it start at a certain RPM?
If MPH look at the DS, if RPM look at the HB....
HISSIN50
34
129
Jul 20, 2006
  • Jul 20, 2006
If you can make it do this while sitting still and revving the engine, the HB is likely.
If it requires moving to make vibes, I like the U joint, clutch imbalance, etc idea.
Good luck.
95Vert
1,785
North Mexico (deep south Texas)
Jul 20, 2006
  • Jul 20, 2006
I was going to say something but these guys beat me to it, but I'll post anyway. hehe
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Jul 20, 2006
  • Jul 20, 2006
motor mount lose? maybe a transmission mount?
F
Fordman302
Orlando, FL
Jul 20, 2006
  • Jul 20, 2006
Thanks for the replies, it only vibrates when I'm moving, sometimes when your lucky you can go through the gears without it vibrating but as soon as you slow down again its gonna happen. It's a pretty serious vibration my speedo shakes and everything. I think I'm going to start with the driveshaft, thanks again!
95Vert
1,785
Jul 20, 2006
  • Jul 20, 2006
If it's that bad, I seriously think it's the driveshaft.
94-302-vert
1,947
NE CT
Jul 21, 2006
#10
  • Jul 21, 2006
  • #10
Driveshaft, or maybe even rear end... after my bad gear install my car was doing this when the pinion bearings got wiped...
MysticKeith50
330
Pennsville, New Jersey
Jul 21, 2006
#11
  • Jul 21, 2006
  • #11
yeah ds...I had that exact problem in one of my fox's and it was the bolts that connect it to the rear.
smitty_64
75
#12
  • Jul 21, 2006
  • #12
I'm with Hissin...Had a harmonic balancer go out and while I was sitting at a red light it felt like I was in a popcorn machine. Once I got up to about 50 it would settle out. Could be U-joints too though. Easily verified on the U-joints. I wouldn't think drive shaft unless it started happening after you got on it or you went four-wheelin',
95Vert
1,785
Jul 22, 2006
#13
  • Jul 22, 2006
  • #13
Do you have an update for us?
F
Fordman302
Orlando, FL
Jul 25, 2006
#14
  • Jul 25, 2006
  • #14
WOW, I couldn't figure out what was going on, so I take it to a trusted shop and they tell me the tranny is done. $1800 installed for a used one, I don't know if I should do it, should I go with another t5 or what, t56 is too much work right now, any adivce?
1TallMF
955
Montreal
Jul 25, 2006
#15
  • Jul 25, 2006
  • #15
What exactly did they tell you they found wrong with the tranny? Sounds fishy to me. Usually if you break a gear or a shaft internally, you will lose function of one or a few gears. I can't see it go bad slowly while at highway speeds, unless it went dry and you seized a bearing. Otherwise, I call BS on this one. Get a second opinion just to be safe.
94-302-vert
1,947
NE CT
Jul 25, 2006
#16
  • Jul 25, 2006
  • #16
And $1800 is extreme for a used trans installed.. you can get a reman cobra t5 for $1000 or under and install it yourself with the help of a buddy in a matter of a couple hours (4 max for a first timer).....
R&R the trans:
1. Car on Jackstands
2. Drain trans
3. Remove DS (4 bolts)
4. Remove shifter handle and rubber boot to floor.
5. Unbolt cross member (2 bolts).
6. Unbolt trans from bell housing (4 bolts).
7. remove trans
8. reverse steps for new trans.
HISSIN50
34
129
Jul 25, 2006
#17
  • Jul 25, 2006
  • #17
I also would want it explained to me how the diagnosis was made (I'm with 1TMF in terms of wondering how this conclusion was reached).
What's a used T5 go for.... Like 100-200 bucks?
Did they say reman'd or just used?
In Orlando, I know you can get some locals to help ya out - or a mechanic to do a side job for you. To swap a trans would be VERY little labor cost.
I would probably also do the clutch and flywheel resurface because that can also cause vibes.
I'd try and get a local to help ya out if I were in the same position.
MHO. Good luck.
95Vert
1,785
Jul 25, 2006
#18
  • Jul 25, 2006
  • #18
I'll second that BS call. Some guy tried to pull this same excuse after I sold him my auto, but it was the driveshaft. Sneaky bastards!!!!!!!!!!!!
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 25, 2006
#19
  • Jul 25, 2006
  • #19
yeah, sounds like they are scamming you. Take it to someone else if you still can't find it and get a second opinion.
Scott
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
K
Intense Shaking problem
  • KP_NewEdge
  • Jun 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 11, 2025
gkomo
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
U
8 Years of Vibration leading to engine knock?
  • UpgradeXP
  • Apr 14, 2025
SN95 V6 Mustang Tech Apr 14, 2025
