car shakes when clutch is released after t5 swap
radtke5.0
11
ok i did a aod to t5 swap. the car start and revs fine, the flywheel has been resurfaced and the clutch is a new spec, used alinement tool and did everthing right i thought ...... but when the car is in gear (any gear) and i start to let the clutch out the car shakes bad. bad enough i don't think i should try to drive it. it would seem something isn't right, the clutch is the only thin i can think of. i need some help thanks :bang:
Not the first time someone has had chattering with a Spec. What stage (we are assuming a Stage 1)?
im not being an ass....but lets get the specifics out of the way first. you do know how to drive stick correct? if so than i would blame it on the spec clutch.
since so many people complain about clutch chatter why dont they change something out in their clutch building process. i could think of two things that would help get rid of the chatter
ok yeah its a stage 1 clutch. yes i know how to drive a manual car, and i made sure the flywheel side of the friction disc when towards the flywheel. damn i'm out of ideas
