Car SOMETIMES doesn't start.
  • Thread starter Thread starter DRock9
  • Start date Start date Jul 15, 2008
D
DRock9
359
  • Jul 15, 2008
I have noticed that in the past few days my car sometimes will not start up, it will crank and sometimes fire but then it will die. Usually I just crank it up again and it will start, I haven't yet been stranded anywhere but I am trying to keep that from happening.
I have checked the Crank but no start checklist but since the problem doesn't happen all the time it is very hard to diagnose.
Have any of you had similar problems before? What could it be?
Thank you.
HISSIN50
34
129
Jul 15, 2008
  • Jul 15, 2008
If you haven't, pull codes.
You will have to jump on it when it won't start and make observations. Note things like if depressing the gas pedal a little helps, or if it only happens when hot or cold, etc.
Good luck.
D
DRock9
359
  • Jul 15, 2008
It seemed to only happen when it was wet out.
I just got a new rotor and cap, i noticed the old one wiggled a little bit.
Is there supposed to be some sort of rubber o-ring type thing that goes on the cap?
HISSIN50
34
129
Jul 15, 2008
  • Jul 15, 2008
The caps do tend to wiggle a hair. They're not screwed down like some 4 banger caps. No o-ring or gasket.
Do you think the cap is getting moisture inside it? Some Wire Drier can help if this is the case.
I kinda wonder if you dont have a bad electrical connection (10 pins, etc) and the moisture is causing resistance in a signal reading.
The forced induction creates a big variable too........
D
DRock9
359
  • Jul 15, 2008
Where can I get wire drier?
I do think it is the moisture, it hasn't happened to me in the dry weather yet...maybe I haven't given it enough time.
I am having a miss when I romp on it really hard, I think it is because I am running stock heat range plugs with 12psi, I need to get the meth working.
HISSIN50
34
129
Jul 16, 2008
  • Jul 16, 2008
Wire Drier is made by Snap as I recall. Better parts stores should have it on their shelves, though I havent bought it in about 10 years (one can lasts forever).
Some guys use WD-40, though I havent tried that before.
If the car has a miss only at higher RPM's, I'd be less inclined to think it was a moisture issue.
You might want to mist the plug wires with a spray bottle of water and see if you note leakage (you have to do this in the dark so be careful of moving parts!) .
D
DRock9
359
  • Jul 16, 2008
Plug wires are fairly new, less than a year old, but then again so was the cap and rotor and I found out the rotor was rusty.
What kind of leakage am I looking for?
Thanks.
HISSIN50
34
129
Jul 16, 2008
  • Jul 16, 2008
Thanks.
When water is sprayed on the wires, it illuminates the leaking spark. It looks like pixie dust (you'll see bluish light scattering around the point of the leak).
There was even a TSB some time back for plug wire leakage (it was actually for crossfiring but the same principle allows for leakage).
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
  • dan50
  • Jul 18, 2026
dan50
