  • SN95 4.6L Mustang Tech
Car Starting Issues...
  • Thread starter Thread starter Kane
  • Start date Start date Sep 29, 2006
Kane
489
Indianapolis, IN USA
Sep 29, 2006
  • Sep 29, 2006
99 Mustang GT, about 59K miles. I've noticed that recently I need to let the car warm up a bit before I take off, or it will bog and hesitate when I get on the gas...but the car has been starting. Now, when I start the car after it's been sitting several hours, it bogs and acts like it wants to cut off. I'll finally get it to smooth out with a little gas. Car runs perfectly fine. The weather has been a little cooler, but I've never had issues starting the car before. Input?
R
Red2000GT
2,450
Regina,Sask.Canada
Sep 30, 2006
  • Sep 30, 2006
1st guess-O2 sensor or sensors.
2nd guess-fuel pump on the way out
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Sep 30, 2006
  • Sep 30, 2006
O2 sensors would throw a code.
Check the IAC (idle air control valve). Could be clogged and causing your problem.
Kane
489
Oct 1, 2006
  • Oct 1, 2006
I had thought oxygen sensors, but there are no codes. I'll check the IAC. Thanks!
M
Mustanggt108
221
  • Oct 1, 2006
i dont think it would be the fuel pump because after the car gets warm , it runs perfectly he said.My guess is the IAC as well , it might need some cleaning.
P
peterman1551
9
  • Oct 2, 2006
P
peterman1551
9
  • Oct 2, 2006
I had the same issues at about 70,000 with my 99 GT. Sounds like it is definitely the IAC. Some say you can remove it and spray it down good with carb cleaner to fix the problem, however, there are internal parts in it that carb cleaner will not clean as I found out. The problem came back quickly. I would replace entirely. Expect that if you keep the car, and even if you properly maintain it, you will need to replace it again at around 100,000 to 120,000. I need to replace mine again and I have 132,000 on it.
Kane
489
Oct 2, 2006
  • Oct 2, 2006
Ok, it was a little warmer here in Indy today, and the car started without ANY problems. Started right up when I left work later on as well. Temperature related problem? I haven't cleaned/replaced the IAC yet.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Oct 2, 2006
  • Oct 2, 2006
It is an intermittant problem that will get steadily worse. I let mine go about a year before I got annoyed enough to replace it.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
J
Car won’t start
  • JLB
  • Nov 15, 2025
SN95 4.6L Mustang Tech Nov 15, 2025
nickyb
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
