Car trouble/check engine light.
1973mach1
457
PA
I have a 1994 v6 mustang, mostly stock just a glass pack on the exhaust. A few weeks back the Check engine light came on, it still seems to drive fine but I get no heat anymore, it comes on ocassionally for a minute then goes cold again. I know its not the headgasket, That went a 2k miles ago and I had new ones installed. The cars not overheating. Im also having a non related problem. When I turn my cars wheel all the way to one side and go to pull out of a parking spot or make a sharp turn the wheen seems to hop like its trying to go forward over the wheel almost and makes a weird noise likes somethings loose. I have new struts and ball joints on it, the lug nuts are tight, any idea's what it might be?
Thanks,
jim
Check engine light---bring it to autozone & have them read the code (they do it for free).
Heat---got coolant?
Hop---when's the last time you had it aligned?
Thanks guys, I added coolant, it seems to get heat now, I still have to get the check engine light checked out, the front wheel hop when turning could be needing an alignment, i'll check that out.
Thanks,
Jim
