  • SN95 4.6L Mustang Tech
Car will not stay running..
  • Thread starter Thread starter ProCharger GT
  • Start date Start date Dec 24, 2006
1 of 2 Next Last
ProCharger GT
153
Cleveland
Dec 24, 2006
  • Dec 24, 2006
Here's the deal..
A little while back, I was driving my car around - it made some popping noises, I was able to drive it home - once there, turned it off. Turned it back on in the morning, it would idle rough around 500 RPM's and die. I have already done the following:
1) Checked the supercharger, it has oil, not making any weird noises - no belt slip.
2) Checked every sensor, everything is clean
3) Alternator was dead, replaced that and the battery
4) Ran it w/o the MAF, same issue
5) Bypassed the supercharger completely, still doing the same thing
I can't find any vaccuum leaks, I'm not leaking any fluids, and the only thing I can think of is that it's not getting enough fuel...after all the starting and stopping, with 60# injectors, there should be SOME fuel smell - but there isn't anything. Aside from the fuel filter, anyone else have ideas? Pumps/BAP/injectors are all brand new and have less than 500 miles on them.
DTNODYA
831
  • Dec 24, 2006
IAC? Reset your computer? Just throwing stuff out there .... Fuel pump?
DropTopPony
Noob Slayer
2,570
south jersey
Dec 24, 2006
  • Dec 24, 2006
Sounds like an IAC to me...cheap and easy to replace.
ADRENLN
2,342
NJ
Dec 24, 2006
  • Dec 24, 2006
what fuel pump are you running? it was fine before with the same tune right?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Dec 24, 2006
  • Dec 24, 2006
what about the plugs have you checked those but it could also be the IAC
ProCharger GT
153
Cleveland
Dec 24, 2006
  • Dec 24, 2006
I was thinking the IAC, but it was just put back on there when the P-51 went on last year...the fuel pumps are the 03/04 Cobra tank/pumps, brand new. The only "old" thing on there is the fuel filter...it's just weird that it made the popping noises prior to this happening. It really sounded like a vaccuum line popped off when it happened....but everything's all hooked up. Plugs have about 300 miles on them, nothing too crazy..
AmBo
1,027
New Jersey
Dec 24, 2006
  • Dec 24, 2006
492rwhp on a stock block?
ProCharger GT
153
Cleveland
Dec 25, 2006
  • Dec 25, 2006
No, check my garage for mods..
the98stang
2,408
Clovis, CA
Dec 25, 2006
  • Dec 25, 2006
Popping from the exhaust could mean timing/tuning issues. Who tuned the car? I don't think it's getting enough fuel like you said...
stangman
2,690
10
69
in a 3 bed, 2 bath
Dec 25, 2006
#10
  • Dec 25, 2006
  • #10
but have you checked the plugs for any damage? if you haven't you need to before you do anything else
ProCharger GT
153
Cleveland
Dec 25, 2006
#11
  • Dec 25, 2006
  • #11
Haven't checked the plugs...and actually, I didn't even bring the car into boost, so I really doubt that unless there was mechanical damage, the plugs would be ok - but I'll double check them.
I'm really leaning to the fuel route, after starting it up a few times in a row, you'd smell gas, especially from that setup. I don't smell anything at all.
the98stang
2,408
Clovis, CA
Dec 25, 2006
#12
  • Dec 25, 2006
  • #12
Check the AFR. If your smelling gas, it's running rich, or you have a leak somewhere.
ProCharger GT
153
Cleveland
Dec 25, 2006
#13
  • Dec 25, 2006
  • #13
That's the problem, I'm not smelling any gas
the98stang
2,408
Clovis, CA
Dec 25, 2006
#14
  • Dec 25, 2006
  • #14
You wouldn't smell gas if it was running lean....
ProCharger GT
153
Cleveland
Dec 25, 2006
#15
  • Dec 25, 2006
  • #15
Right, and the tune is all dialed in, so I highly doubt it's that. That's why I'm leaning to fuel filter - if it's clogged, it might be getting just enough to turn over, and thats it. Couldn't hurt changing...I'll be putting that on my list of things to try. If that doesn't do it, then I'll look to injectors/ignition. It's just so weird that the popping noise is what caused this issue in the first place...I wasn't even driving the thing hard, I'm talking < 3000 RPM's when I heard it, doin about 35 MPH.
J
jtroush2002
41
please ship to: Irving, TX
Dec 26, 2006
#16
  • Dec 26, 2006
  • #16
any codes?
first off check your battery, coils and spark plug wires, check spark plugs, any misfires?, spark @ cyl., check fuel pump and voltage to it, fuel filter, injectors, stuck PCV valve, IAC, TPS, vacuum leaks and check the EVAP system.
these are not in specific order, just throwing out things you should check.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Dec 26, 2006
#17
  • Dec 26, 2006
  • #17
First thing to always do is get the car on a scanner. At least then you can possibly pinpoint where to start looking. Look at things like your O2 readings, O2 crosscounts, pulsewidths, sensor data, etc.
I also agree that it would be a good idea to check the plugs. These motors do not play nice with spark plugs. If you do end up checking the plugs, post some clear closeup pics so we can help you read them.
ProCharger GT
153
Cleveland
Dec 26, 2006
#18
  • Dec 26, 2006
  • #18
Not throwing any codes, battery is new, coils checked fine. Fuel pumps are brand new, along w/ injectors and BAP. PCV valve was checked, it's fine. IAC is under the P-51 so it's gonna be difficult to check that w/o ripping apart the front of the engine again, but if it must be done - it must be done. When it does run, I don't hear any vaccuum leaks, nor do I see anything loose. We bypassed the blower, all the accessories, and the MAF, unplugged the TPS - same issue.
As far as O2 stuff goes, it was hooked to the dyno recently and all the a/f curves were dialed in. I'll try and pull the plugs sometime between today and tomorrow, at least pull a few, and see if that's causing the issue. I'm also gonna go pick up a fuel filter.
stangman
2,690
10
69
in a 3 bed, 2 bath
Dec 26, 2006
#19
  • Dec 26, 2006
  • #19
not true
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Dec 26, 2006
#20
  • Dec 26, 2006
  • #20
I would think IAC myself.
I've replaced IAC 3 times. 2nd one lasted less then 6 months...
1 of 2 Next Last
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
  • Gulftown980x
  • Jul 29, 2026
squeak93
