Car Wont Crank
1989MustangLX
118
Canada
The car is being a huge pain in the ass lately, I finally get it all buttoned up after installing a new starter, changing the head gaskets, and replacing the intake gaskets, and it is still doing this.
When I put the key in "crank" all I get is a loud buzzing sound, presumably from the starter solenoid on the side of the engine bay. I have a new starter, new battery, new battery wires, a new ground from the firewall to the back of the intake, and a second ground from the back of the passenger side head to the passenger side of the engine bay. The grounds are scraped free of paint underneath, but even jumping the two posts on the solenoid does nothing but make a little spark.
I checked out the cable running from the solenoid to the starter, and it is fine. The starter was tested when I bought it and the parts guy told me it worked fine, since my battery before wouldnt turn it over out of the box (dead battery). I put a breaker bar on the crank and the engine turns over, so it isnt seized. I really don't know what to do right now, and I would appreciate any help you can provide.
If you apply the e-brake and then remove the slide-on connector (the thin wire at 12 o'clock on the solenoid) and touch it to the battery lug of the solenoid, does the engine crank over? (Be real careful since this bypasses the safety features in the starter circuit).
If not, does jumping the two big lugs on the solenoid start the car?
If not A but B, that suggests a solenoid issue.
Do you have sufficient motor grounding?
Random thoughts. Good luck.
If jumping the two big lugs did nothing, the little one wont be able to do anything.
Double check battery charge, cable connections and the ground you're going to do. You can use jumper cable to parallel existing cables for quick diagnostics (including the grounds).
Good luck.
Jumping the neutral safety switch made the buzzing sound that it makes when the key is put to crank. I get continuity from the block to the body of the car, and I get continuity from the hot wire to the starter and the intake, so the grounds are fine along with the starter wire. Battery voltage is 12.42 volts.
A measure of continuity is not a great test to ensure one has sufficient grounding for the application (such as your starter). A paperclip will ohm out wonderfully but do nothing to help the starter, via the motor, achieve proper grounding. As the cables break down internally, they cant carry the load they once did.
What buzzing noise does the car make while cranking? Mine dont buzz - they whir as the starter turns the motor over. I dont understand the noise you're describing.
Good luck.
Ohming out a ground is not the best way to find out how good they are. The amount of resistance that will diasble a starter is less than the resistance of the test leads used to connect it to the ohmmeter.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while it is under load: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help
Here's a checklist:
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order.
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
4.) Then pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems. See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars .OR see http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars. See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
8.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Thanks everyone for your help. My buddy the mechanic came over today. All he had to do was hook up a jumper cable from the negative post of the battery to the metal backplate of the solenoid, and the car cranked and caught right away. He says "just like I thought, bad grounds". He's a good guy, now I am going to get him some gift certificates from Tim Hortons for coming over to my house after work to do this for me. I will be re-cleaning the grounds, replacing some, and relocating the negative battery cable to the block instead of the intake. I have to adjust the rockers properly now, but I have all the information I should need to do that. Once again, thanks.
