Car Wont Run!!
  • Thread starter Thread starter se7en-zero
  • Start date Start date Jan 18, 2004
se7en-zero
58
  • Jan 18, 2004
Hey guys,
Just got a new Holley 600CFM carb and a Weiand intake...They are installed, but the car sputters and wont hold idle, or run right at all...
If any one has pictures of this setup, or one similar, showing where the vacuum lines go, that might help. Any other suggestions would be awesome!!! Thanks in advance!
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Jan 18, 2004
  • Jan 18, 2004
did you torque the manifold bolts correctly ? It sounds like you have a massive vacuum leak somewhere. How about the carb itself, is it correctly bolted to the manifold?
67GTA-FB429
777
Tri-Cities, Wa
Jan 18, 2004
  • Jan 18, 2004
Did you remember the gaskets? Did you tighten the carb-manifold bolts/nuts? Do you have an electric fuel pump or mechanical? If you have an electrical, let it run and check your float levels, you may be starving the engine or flooding it. I had a stuck float last year and it would barely run, the only way to get home from a buddy's house was to keep turning my electric fuel pump on and off (switch on the dash).
se7en-zero
58
  • Jan 18, 2004
How do I check for manifold vacuum? thanks in advance!!!1
crushnut
870
Oregon
Jan 18, 2004
  • Jan 18, 2004
With a vacuum guage, im guessin you dont have one though.
foghorn67
I'll save you the time and choke myself
1,532
Orange County, CA
Jan 18, 2004
  • Jan 18, 2004
You can buy a vacuum gauge for under 20 bucks.
be sure to the know the difference between ported vacuum and timed vacuum on the carb. one is a constant source, and the timed is for the distributor for the vacuuum advance.
67GTA-FB429
777
Tri-Cities, Wa
Jan 18, 2004
  • Jan 18, 2004
What did you have on there before the weiand intake?
se7en-zero
58
  • Jan 19, 2004
stock intake/carb...
I have gotten a bunch of info from a ton of people, hopefully i can get thte sorted out today...Thanks agian guys!!
10secgoal
2,801
San Diego
Jan 19, 2004
  • Jan 19, 2004
Almost guarantee it's a vacuum leak. Check your oil, it probably looks like a milkshake. If not fire the car up and cover the carb with your hand a little, not all way though. If it runs better, you've got a leak. That's the cheap way to check it. Another way is to spray the manifold with carb spay or brake cleaner. Again if it runs better.... but that only works if you are leaking from the top. Good luck.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
