Car wont shift after engine install aod
  • Thread starter Thread starter NewToFord
  • Start date Start date Mar 5, 2011
N
NewToFord
318
CT
Mar 5, 2011
  • Mar 5, 2011
Heres the story The car is an 86 efi with and auto it is all stock. I pulled the motor to change the oil pan. Trans stayed in the car. I had some trouble with the install and put it in and the converter wasnt in all the way. I did NOT start the car. I pulled it all apart and I think I got it right. Anyway I go to start the car tonight it wont start. I bypass the igntion and start it with the soleniod and it started and the reverse lights were in. The car was in reverse. I climb underneath the car and pushed the linkage ahead into park and the car started fine after that. Then I went to put it into drive and the car wouldnt move. It stalled and I put it back into park and no start again. Now I can push the car in any gear. The shifter says Park but the car pushes like its in neutral. Any suggestions? Is my linkage messed up? Is this a torque converter issue? What should I look for? Thanks for the help.
Kdubslugga
1,515
Akron, OH
Mar 5, 2011
  • Mar 5, 2011
sounds to me like a linkage issue. Will the car start without bypassing the starter solenoid? like try starting the car in Park, Neutral, REverse, drive see if it starts in any of these selections. be careful!
N
NewToFord
318
CT
Mar 6, 2011
  • Mar 6, 2011
The car will start if I push the linkage on teh trans all the way ahead. It will not start in gear or reverse. Could it be the TV cable?
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • dan50
  • Jul 18, 2026
dan50
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
