Car wont start
  • Thread starter Thread starter Munnstang
  • Start date Start date Oct 10, 2004
Munnstang
287
Winnipeg Manitoba
Oct 10, 2004
  • Oct 10, 2004
Yesterday my car was running and starting fine, then I went to start it and nothing. CAA came to tow me home, and we got it started by tapping the starter solenoid as I tried to crank it over. I tried tapping it earlier, but I guess it did no good as the motor wasnt trying to turn over. Anyways, back to today. The car wouldnt start again, after starting fine several times since the CAA incident. I managed to get it home by push starting it, and I replaced the starter solenoid, but still nothing. When I try to start it, something makes a clicking sound, and for some reason my stereo gets no power, but thats probably just a fuse. Is there a way to check if my starter is fubar? Thanks.
HISSIN50
34
129
Oct 10, 2004
  • Oct 10, 2004
it sounds like the battery or cables are kaputt. do you lose your presets when you try to crank it (or do the interior lights go out)?
if no to those questions, put a test light on the solenoid trigger (wire that pulls off) and see if you have 12 volts while cranking. if you do (assuming a full battery, cables alright, etc, see below).
you can also jump the solenoid (across the big lugs). if it starts this way, but the test light did not light above, that suggests the solenoid.
however, first blush guess would be a cranking/conductivity issue (battery, cables, etc). dont forget grounds. good luck.
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
