Car wont start
  • Thread starter Thread starter JoshP82
  • Start date Start date Feb 8, 2006
J
JoshP82
91
Burbank, CA
Feb 8, 2006
  • Feb 8, 2006
Hey guys im having some problems with my car I havent drove my car for a couple months and today I tried to start it but it would not start I turn the key and hear the fuel pump and then the check engine, oil and air bag lights go on then the only one that stays on is the check engine light when I try to start it the oil light comes on and when i let go of the key it goes off, what do you guys think the problem is?? Could it be the starter thats shot???
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Feb 8, 2006
  • Feb 8, 2006
so it wont even turn over????
J
JoshP82
91
Burbank, CA
Feb 8, 2006
  • Feb 8, 2006
No it dosent turn over so im guessing it could be the starter thats shot
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Feb 8, 2006
  • Feb 8, 2006
did u check all the connections, solenoid, all the other lil stuff like that???
J
JoshP82
91
Burbank, CA
Feb 8, 2006
  • Feb 8, 2006
ya i checked them all.
HISSIN50
34
129
Feb 8, 2006
  • Feb 8, 2006
If the car was not driven in several months, do you know that the battery is not nearly dead?
Good luck.
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Feb 8, 2006
  • Feb 8, 2006
then take it off and have auto zone check it. they will for free.
J
JoshP82
91
Burbank, CA
Feb 8, 2006
  • Feb 8, 2006
Ya the battery is good i had it recharged today in the morning.
J
JoshP82
91
Burbank, CA
Feb 8, 2006
  • Feb 8, 2006
Forgot to mention also the battery light stays on when i try to turn it over and before i try to start it, Also where is a good spot to jack the car up so i can take off the starter and have it checked out, how hard is it to take the starter out and put it back in??
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Feb 8, 2006
#10
  • Feb 8, 2006
  • #10
i think its supose to do that
HISSIN50
34
129
Feb 8, 2006
#11
  • Feb 8, 2006
  • #11
And you know you have 12 volts reaching the solenoid to make the car start? If not, the clutch/neutral safety switch can be inhibiting the signal from reaching the solenoid. The ignition switch could also be at fault, as could the solenoid, primary electrical system, etc.
I would go through the control side of the starter wiring and make sure it is up to snuff. Jrichker has some very helpful posts on this topic, with pics and a systematic approach.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 9, 2006
#12
  • Feb 9, 2006
  • #12
As requested...
Here's a checklist:
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
4.) Then pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems. See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars .OR see http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars. See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
8.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Feb 9, 2006
#13
  • Feb 9, 2006
  • #13
When u turn the key, do you hear anything at all? Low battery voltage will allow the interior lights and all that to work, but whe you turn the key to start the car nothing will happen. Also check your battery terminal connections and make sure they are clean and the cables are connected well. I have had times when the terminals had just enough crap on them that the car wouldnt start. A quick cleaning of the terminals and it fired right up. Double check all the simple things before you start taking things off--like the starter. It sounds like something with the battery to me.
J
JoshP82
91
Burbank, CA
Feb 9, 2006
#14
  • Feb 9, 2006
  • #14
Yup your right it was the battery. I went to AutoZone and they checked it out for me and they told me it was a dead battery, but I had it charged last week and now it's dead, one of the guys told me that if there’s electrical problems on the car that it can basically kill the battery, Which I thought was BS, So take it for what its worth I have no stereo at all in the car and the alternator is brand new so I don’t know if I should buy another Optima or he said getting a Duralast Gold one that those are wet cells. What route shall I go amigos?
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Feb 9, 2006
#15
  • Feb 9, 2006
  • #15
i would go optima. they have gel inside(i think) and will prolly last longer but are more expensive
HISSIN50
34
129
Feb 9, 2006
#16
  • Feb 9, 2006
  • #16
Might be time to whip out the DMM and start searching for a drain.
Good luck.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Feb 9, 2006
#17
  • Feb 9, 2006
  • #17
:Word:
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
D
Theft light staying on car starts right up
  • dtarang
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 15, 2026
dtarang
D
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
