A little history... Car ran fine until I tore it down over Xmas except it blew the head gaskets all over the place. Found the exhaust valves got in a fight with the pistons because AFR didn't hone the guides right when new. Fixed that and put it back together after finishing the port work on the lower intake. Electronicly it was ok, now it's dropping out of closed loop after it heats up, or sometimes it just doesn't go closed loop. When in open loop it idles around 1300 and the A/F stays slightly rich, plus it'll surge when cold. Coded it and fixed everything that came up (mostly EGR's EVP not reading correctly). When I tore it down I left the ten pins connected and just draped the harness over the cowl like I always do. Twice while KOER coding it it was running in failure mode (open loop), but didn't have codes. You get a failure mode indication when the cylinder ID mismatches on the scanner while testing.
So far I swapped the EGR system (valve, EVP sensor, solenoid) and plugged the ECT into a spare sensor. I have to pop the upper off to swap the ACT out. I'm going to do that today and look for damage under the upper intake with the wiring. I'm good at isolating these problems, but this one is really kicking my behind.
I have to swap out a water pump on a customers '95 lightning today (need a break from the stang). The ranchero is sitting next to stang so I can swap parts back and forth, but I'm running out of ideas or reasons why it's acting up.
Jamie
Jamie
